Entity sets - containment and parent-child
Carl Ollivier-Gooch
cfog at mech.ubc.ca
Tue Nov 17 10:40:53 CST 2009
Mark Beall wrote:
>> In most cases you can support either, and which one you want depends
>> on the usage. I think this would be far more useful though if there
>> were a function to change the type of relation dynamically.
>> Requesting an entity-set type be changed to an entity-both type, and
>> back again, for smoothing, is the easiest use case for this, but
>> adaptive refinement is another good example.
> I don't think I understand why you would want to change the relation. If
> I have classification as an entity-set relation, why would I want it
> differently. I will say that I'm assuming that iRel_getEntEntAssociation
> always allows you to efficiently query the relation in either direction
> (this is implied due to the existence of the "switch_order" argument).
Here's an example: Suppose you're doing swapping, or any other
topological modification to a mesh. Chances are excellent that you only
want to do the 2-2 swap on the surface if both surface faces classify on
the same model face. Now, if you've got an entity-entity relation
giving you classification, that's an easy test. On the other hand, if
you've got a geometric entity-mesh set relation, you have to find out
which set a mesh face is in, which can only be done through an
exhaustive search of faces. So the higher memory (e-e) relation is much
lower CPU.
Carl
Dr. Carl Ollivier-Gooch, P.Eng. Voice: +1-604-822-1854
Associate Professor Fax: +1-604-822-2403
Department of Mechanical Engineering email: cfog at mech.ubc.ca
University of British Columbia http://www.mech.ubc.ca/~cfog
Vancouver, BC V6T 1Z4 http://tetra.mech.ubc.ca/ANSLab/
More information about the tstt-interface
