Entity sets - containment and parent-child
Mark Beall
mbeall at simmetrix.com
Mon Nov 16 14:28:04 CST 2009
On Nov 16, 2009, at 2:54 PM, Tim Tautges wrote:
> A
>> couple of questions:
>> - createAssociation implies that there can only be a single
>> relation between two interfaces. Offhand I can't think of a example
>> of where there might be more than one, but it seems it might be
>> possible.
> I think so too. This is one of the reasons I think it's useful to
> have distinct "relation" objects. The fact that the interface
> doesn't seem to support a variety of uses is more a factor of nobody
> really using it besides me.
> In the longer run, I see there being other pairwise relations too,
> e.g. a field with a tag.
However, in the case where there is more than one relation possible,
there would also need to be a way to "describe" what relation you are
asking for. At this point it would seem that if I'm asking for a mesh-
model relation, then I'm, by definition, asking for classification.
Also, I think there is a need to define what would be in the
classification relation. By "define" here, I either mean that it's
documented what this particular relation will be or there is a way for
the user to request that certain information be there.
For example, let's consider a model face and the mesh classified on
it. I can see reasonable implementations that would only give the list
of mesh faces classified on the model face, in our implementation I
can also give you the mesh edges and vertices. If an application needs
the vertices classified on a model face it's going to work with one
implementation and not with the other (unless the developer is very
careful to code for every possible case - and I think it's kind of a
waste for every developer to have to do that).
>> - why does createAssociation take in whether the relation is an
>> entity or a set rather than that being returned? It makes sense if
>> the relation is empty, doesn't really make sense if the relation is
>> something like our classification that already exists (or
>> classification in general since there really should only be one way
>> to describe that).
> In most cases you can support either, and which one you want depends
> on the usage. I think this would be far more useful though if there
> were a function to change the type of relation dynamically.
> Requesting an entity-set type be changed to an entity-both type, and
> back again, for smoothing, is the easiest use case for this, but
> adaptive refinement is another good example.
I don't think I understand why you would want to change the relation.
If I have classification as an entity-set relation, why would I want
it differently. I will say that I'm assuming that
iRel_getEntEntAssociation always allows you to efficiently query the
relation in either direction (this is implied due to the existence of
the "switch_order" argument).
mark
More information about the tstt-interface
