Ordered entity sets
Tim Tautges
tautges at mcs.anl.gov
Thu Nov 12 11:28:54 CST 2009
I think that's correct.
- tim
Mark Beall wrote:
> If an entity set is ordered it seems that it is not necessary to
> preserve the ordering of the entities and the entity sets together, only
> separately. What I mean is the following:
> If I do the following operations on the ordered entity set A:
> - add entity a
> - add entity b
> - add entity set B
> - add entity c
> - add entity set C
> Since I can only ask for either the entities or the entity sets in A
> separately (the only way I can get the entity sets in A is through
> iMesh_getEntSets, right?), it doesn't matter if the implementation
> doesn't know that set B was added between entities b and c, just that
> the order of the entities is abc and the order of the sets is BC.
> Is that correct?
> Thanks,
> mark
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
More information about the tstt-interface
