Proposal for telling an implementation what adjacency info an app/service needs
Carl Ollivier-Gooch
cfog at mech.ubc.ca
Fri Nov 6 14:36:22 CST 2009
One thing that's been discussed, and even openly experimented with is a
way to inform a mesh database of the actual adjacency information
required by an app/service. (Also, which entity types need to be
iterable.) This is how the swapping service communicates its adjacency
needs with MOAB, for instance. FMDB's internal capabilities should
match up very well with this notion as well, allowing specialization
when appropriate. Other implementations (GRUMMP, for instance) may or
may not be able to take much if any advantage of this, but that's no
reason not to allow an app/service to express what it actually needs.
The other possibility is to specify this at creation time, but if we're
going to do that, we should do the same with spatial dimension. This
change provides the needed (?) capability in a way that's symmetric with
other calls.
Carl
/**\brief Tell an implementation the minimum adjacency information
required
* Tell an implementation the minimum adjacency information required
* by a service or application, in the form of an adjacency table.
* This table is a 4x4 array, with indices 0-based, where A(i,j)
* (i=row, j=column) is 1 if the service or application will require
* adjacencies between entities of dimension i to entities of
* dimension j and 0 otherwise. A(i,i) is 1 if the service or
* application will iterate over entities of dimension i and 0
* otherwise.
* \param instance iMesh instance handle
* \param *adjacency_table Array representing adjacency table
* required
* \param *err Pointer to error type returned from function
void iMesh_setAdjTable (iMesh_Instance instance,
/*in*/ int* adjacency_table,
/*out*/ int *err);
Dr. Carl Ollivier-Gooch, P.Eng. Voice: +1-604-822-1854
Associate Professor Fax: +1-604-822-2403
Department of Mechanical Engineering email: cfog at mech.ubc.ca
University of British Columbia http://www.mech.ubc.ca/~cfog
Vancouver, BC V6T 1Z4 http://tetra.mech.ubc.ca/ANSLab/
More information about the tstt-interface
