entity set implementation for iMesh and iGeom
Tim Tautges tautges at mcs.anl.gov
Fri Nov 6 08:41:21 CST 2009
I strongly agree with Jason's statement.  Documenting the syntax and usage of each function in the text of the User's
Guide as well as the doxygen'd header file will always result in inconsistency.  It also obfuscates the important
information in the User's Guide that does not appear in the header files.  I don't see getting rid of the syntax
documentation in the header, so that means it should be taken out of the User's Guide (and the doxygen output should be
incorporated into an appendix).
- tim
Jason Kraftcheck wrote:
> Mark Shephard wrote:
>> Is this everything and is it all up to date?
> I doubt it, but these are supposed to be the most current versions that we have.
>> I do not see iMeshP stuff and lots of the stuff is still called TSTT
>> (which makes me wonder if it is up-to-date).
> Is there any iMeshP documentation beyond the doxygen-formated comments in
> the header?
>> If this is not complete or up-to-date, I guess that is one of the
>> overall software clean-up things we need to get done as part of the
>> processes we discussed at the last boot camp.
> Much of the current iGeom and iMesh users' guides are composed of API
> documentation similar to what is in the doxygen-formatted comments in the
> headers.  The duplicate effort and potential source of inconsistencies is
> sub-optimal.  Doxygen can generate latex from the headers that could be
> included in the users' guides as an appendix.
> - jason
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
More information about the tstt-interface mailing list
