proposed minor change to iBase
Tim Tautges tautges at mcs.anl.gov
Wed Nov 4 08:52:38 CST 2009
Carl Ollivier-Gooch wrote:
> Also, it got me thinking about iMesh_getDescription, which I looked up.
> There are two possible interpretations here:
> 1.  An app hits an error code and asks for a description of it; the
> implementation has a string for each error code.  This would presumably
> take a "/*in*/ int err".
> 2.  An app asks what just happened; the app has the error code and a
> (possibly context-specific) error description stored somewhere, and
> returns those.  This requires a "/*inout*/ int *err", which is what we
> have.
> The former is what I'd assumed this function does, but the signature
> suggests the latter.  So which do we mean?  And if the latter, why
> bother returning the error code, which the app already has as a side
> effect of the function call, and has to check to know whether to request
> a description anyway?
> And in any even, the function signature suggests that the app is going
> to pass in a pre-allocated char array of size descr_len, or at least,
> that's the obvious interpretation of the C.  But a Fortran
> implementation presumablywon't like that much.
> Carl
I've always assumed that getDescription gave context-sensitive help after a non-success return code.  I think #1 above
doesn't do us much good, and an implementation without the ability to do #2 is far less useful.
The fixed-size string is actually for fortran; from fortran, strings are always fixed-size (i.e. the length at the end
of the arg list is always passed by value).
- tim
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
More information about the tstt-interface mailing list
