Help getting HelloMeshF77.F to run on GRUMMP
Mark Miller
miller86 at llnl.gov
Tue Nov 3 17:59:48 CST 2009
Hi All,
Ok, got HelloMeshF77.F working against GRUMMP.
I did NOT need 4.3 gcc. I used gcc-3.2.3. %VAL() has been part of
Fortran interface to gcc for 'simple' types for quite a while I guess.
I turns out the GRUMMP implementation was taking the name of the file as
passed from fortran and just using it like a null terminated string. I
added code to null terminate the string and HelloMeshF77.F now works.
So, I learned something. I do think we need to test the Fortran
interface. I think Tim suggested last week that linking alone may not be
a sufficient test and we might want to ensure we at least test those
calls that pass string valued stuff. And, this experience bears out that
concern.
On Tue, 2009-11-03 at 14:25 -0600, Tim Tautges wrote:
> You're only partly correct there. First, I don't think g77 is going to work for you at all, you should be using
> gfortran. Second, you'll need the 4.3 series of gcc, because it was only with that version that gfortran supported call
> by value. Third, you don't need to link with g++, as long as the linker you are calling is told the correct libraries
> to link in. In MOAB, we accomplish this by putting those extra library link parts in a make variable which can be used
> by applications. I don't remember, but I think they may be appended to IMESH_LIBS.
> > Finally, I cannot get HelloMeshF77 to run successfully. GRUMMP is always
> > trying to add '.vmesh' to the filename. That is fine, but try as I
> > might, no matter what I do, iMesh_load() winds up getting some scrambled
> > name.
> That's a GRUMMP issue, I suspect.
> - tim
> > Mark
Mark C. Miller, Lawrence Livermore National Laboratory
email: mailto:miller86 at llnl.gov
(M/T/W) (925)-423-5901 (!!LLNL BUSINESS ONLY!!)
(Th/F) (530)-753-8511 (!!LLNL BUSINESS ONLY!!)
More information about the tstt-interface
