proposed minor change to iBase
Jason Kraftcheck
kraftche at cae.wisc.edu
Tue Nov 3 17:21:58 CST 2009
Mark Miller wrote:
> I don't have any experience/history of this enum within TSTT/ITAPS
> context.
> However, I recall having a similar library setting in another project.
> It was designed to support two modes of interaction with the library...
> 1. Test the return value (or error code in case of ITAPS) where
> an application was coded like so...
> iMesh_newMesh(...&err);
> if (err != iBase_SUCCESS)
> do something for error
> 2. Try/catch mode where the application was coded like this...
> TRY {
> iMesh_newMesh(...);
> } CATCH {
> } ENDTRY
> The calling application would TELL the library how to behave; either
> throw or return with error code set. The library would then behave as
> the caller wished. However, we wrote the library from scratch with this
> in mind. Retro-fitting existing implementations -- if they were not
> already set up for this -- may be more trouble than its worth.
> Nonetheless, I think this kind of control is useful as it permits both
> programming styles.
That's interesting but not applicable here: a) no C standard yet includes
exceptions and b) the values for the enum are:
enum ErrorActions {
SILENT, // does nothing, not recommended
WARN_ONLY, // prints something, but nothing else
THROW_ERROR // throws an exception
More information about the tstt-interface
