Additions to the repository
Carl Ollivier-Gooch
cfog at mech.ubc.ca
Thu Dec 10 03:29:11 CST 2009
Tim Tautges wrote:
> Carl Ollivier-Gooch wrote:
>> In the short term, definitely, because I'm not currently taking
>> advantage of the name bindings, so whatever the Fortran compiler
>> normally does happens with those names. I did this because, for some
>> reason, gfortran 4.3.x doesn't support name bindings. In the long
>> run, I think the usual preprocessor magic can be used to have the same
>> effect.
>> In the longer run, I'll wonder aloud whether we shouldn't look to some
>> other solution for F77 compatibility. For instance, commercial
>> compilers presumably support Fortran 2003 and 77 in the same
>> executable, so the cost to applications of compiling routines that
>> access iMesh using the F2003 capabilities may not be too painful.
>> Alternatively, the wrappers to hide some of the ugliness that Fortran
>> pushes on us (and fix the name thing) would be very thin, much thinner
>> than the wrappers we all already have to convert iMesh calls to native
>> database calls.
> Is there something about the current cpp-based name mangling that
> doesn't work in F2003, or just that there seems to be a more elegant
> mechanism in F2003 to handle C names? If the latter, I for one don't
> have time to change gears this late in the game. I also am skeptical
> about requiring F2003 for any f77 application. The commercial compilers
> may have caught up, but what about those on the petascale machines?
> Also, I'd assert that compatibility with gfortran buys us mindshare,
> which is almost as important. Finally, if we open up the discussion
> about wrappers at this point, we could probably spend the next 6 months
> figuring out the right solution, and another year before all the
> implementations catch up. I think the time would be better spent
> implementing the parts of our current spec which nobody has implemented
> yet.
I certainly am not going to push particularly hard on this. But the
reasons I see for wrappers have a lot more to do with the hassles of
string passing compatibility and a lot less to do with elegance.
Your point about the compilers on the petascale machines is well taken,
and I don't know the answer.
Finally, as a matter of curiosity, when you refer to things that aren't
implemented by anyone yet, I assume you're talking iMeshP rather than
iMesh? If not, what parts of the iMesh spec are you referring to?
Carl
Dr. Carl Ollivier-Gooch, P.Eng. Voice: +1-604-822-1854
Associate Professor Fax: +1-604-822-2403
Department of Mechanical Engineering email: cfog at mech.ubc.ca
University of British Columbia http://www.mech.ubc.ca/~cfog
Vancouver, BC V6T 1Z4 http://tetra.mech.ubc.ca/ANSLab/
More information about the tstt-interface
