Additions to the repository
Tim Tautges
tautges at mcs.anl.gov
Tue Dec 8 17:00:34 CST 2009
Carl Ollivier-Gooch wrote:
> Hello, all.
> I am (finally) finishing up sending the iMesh paper back to ACM TOMS
> (revisions to the actual paper were very minor; the holdup was nearly
> entirely me procrastinating, plus a last minute rush to do the things
> below.
> As part of this process, I've created two (presumably) useful things:
> 1. A reference implementation of iMesh. This is GRUMMP stripped down
> to the bare database, so the iMesh wrappers are actually 2-3 times as
> much code as the database itself. And yes (unlike GRUMMP) it will read
> set and tag data... time to backport.... The tarball for this will
> appear in svn about the time you get this email. It's been tested
> against the compliance test suite and the swapping service, but I'd
> appreciate it if those of you who have other stuff to test it against
> would do so at your convenience.
> 2. A set of Fortran 2003 bindings for the interface, and a F2003
> version of one of the example programs. Fortran 2003's C
> interoperability stuff makes it much easier to handle pointers, etc.
> Strings still suck. But F2003 also eliminates the painful business with
> adding underscores to get name mangling right, as it's possible to
> specify the C name that a Fortran interface binds too. (Of course, gcc
> 4.3 doesn't support that particular feature yet...). This stuff, too,
> will be appearing in SVN any second now.
Will this application successfully link against an iMesh implementation that's compatible with the current approach to
Fortran, i.e. one with underscores and function name case modified according to the _protos.h file?
- tim
> I also (while checking the correctness of the machine translation of
> iMesh.h into a F2003 module) fixed some comments in iMesh.h about
> variable intents.
> Finally, a question: is our website a mirror the www directory in the
> repository, or is getting this stuff accessible on the website going to
> take more than that? (Yes, I intent to label the F2003 stuff as alpha,
> and the ref impl as beta...)
> Cheers,
> Carl
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
More information about the tstt-interface
