[Swift-user] trunk-cobalt block task ended prematurely
Ketan Maheshwari ketan at mcs.anl.gov
Mon Mar 2 15:47:48 CST 2015
I trying to run on BG/Q with local:cobalt with trunk but Swift crashes with
the following error:
Caused by: Exception in bgsh:
    Arguments: [/home/ketan/SwiftApps/subjobs/mpicatsnsleep/mpicatnap,
/gpfs/mira-home/ketan/SwiftApps/subjobs/mpicatsnsleep/./data.txt,
/gpfs/mira-home/ketan/SwiftApps/subjobs/mpicatsnsleep/./outdir/f.0002.out,
1]
    Host: cluster
    Directory: catsnsleepmpi-run001/jobs/b/bgsh-3nq3uc5m
exception @ swift-int-staging.k, line: 165
Caused by:
exception @ swift-int-staging.k, line: 160
Caused by: Block task failed: 0302-2109420-000000 Block task ended
prematurely
In the log, I see the qsub call being made and a jobid is returned.
However, I could not figure what is the cause for the task to fail.
One more thing I noticed when translating from old sites conf to new is
that the new conf did not accept the property "globus:mode = script".
A full run log is attached. Thanks for any suggestions.
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20150302/df9a7305/attachment.html>
Type: application/x-gzip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20150302/df9a7305/attachment.bin>
More information about the Swift-user mailing list
