[Swift-user] import position in swift script
Mihael Hategan
hategan at mcs.anl.gov
Thu Jun 18 14:20:50 CDT 2015
I don't think imports were meant to be used as a templating scheme,
which is why they are restricted to be only at the start of a script.
The alternative amounts to a dynamically scoped, no interface function
call. So I don't think avoiding argument list bloat is a good enough
reason to allow that, especially when you can package complex argument
lists in a structure.
Are the defs just values or do they also define behavior/functions?
Mihael
On Thu, 2015-06-18 at 18:18 +0000, Max Hutchinson wrote:
> Not scattered; at the end. I will have ~10 use cases, each written as a
> different defs file (i.e. defs_a.swift, defs_b.swift, etc). For each
> use-case, the run.swift, which is a big foreach loop, is the same. Given
> this structure, I can think of at least 4 organizations:
> 1) run.swift imports "defs_a" or "defs_b". To change use cases, the
> import in run.swift is edited. This is what I currently do but forces me
> to either serialize inter-script execution or edit scripts that are in the
> process of being executed.
> 2) defs_a.swift, defs_b.swift, etc import "run". This seems clean and is
> what I want to do.
> 3) Wrapper scripts are created to contain both imports (i.e. a_wrap.swift
> : ```import "defs_a"; import "run"```). This currently works, but results
> in script bloat.
> 4) Wrap the contents of run.swift in a procedure, import it at the top of
> defs_{a,b,...}.swift, but then call it at the bottom. This is surely the
> "right" way to do it, but its more effort and could have argument list
> bloat.
> Since each of these option is semantically identical, why not allow the
> user to pick their preference?
> On Thu, Jun 18, 2015 at 1:07 PM Mihael Hategan <hategan at mcs.anl.gov> wrote:
> > Yes, but I don't think it should.
> > Why is it important to have import statements scattered through the
> > script?
> > Mihael
> > On Thu, 2015-06-18 at 17:58 +0000, Max Hutchinson wrote:
> > > Could that constraint be relaxed?
> > > On Thu, Jun 18, 2015 at 12:47 PM Mihael Hategan <hategan at mcs.anl.gov>
> > wrote:
> > > > Hi,
> > > > Yes. Imports must come before other types of statements.
> > > > Mihael
> > > > On Thu, 2015-06-18 at 17:20 +0000, Max Hutchinson wrote:
> > > > > Do all import statements need to come before executable statements?
> > > > > I have two scripts: defs.swift and run.swift. If run.swift starts
> > with
> > > > > import "defs";
> > > > > then everything works fine. If instead defs.swift ends with
> > > > > import "run";
> > > > > I get this error:
> > > > > Swift trunk git-rev: 1d512cbda070d363e8ec3cf16e77dfcddc6e66cb
> > > > heads/master
> > > > > 6377
> > > > > RunID: run011
> > > > > Could not compile SwiftScript source: line 24:12: unexpected token: ;
> > > > > where line 24 is:
> > > > > int foo = 1;
> > > > > Thanks,
> > > > > Max
> > > > > _______________________________________________
> > > > > Swift-user mailing list
> > > > > Swift-user at ci.uchicago.edu
> > > > > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
More information about the Swift-user
