[Swift-user] Sites configuration examples
Yadu Nand Babuji yadunand at uchicago.edu
Tue Jul 14 12:09:44 CDT 2015
Hi Aurelien,
Could you try setting the following :
export GLOBUS_HOSTNAME=<public_ip_of_your_machine>
You could use these to limit port if necessary:
export GLOBUS_TCP_SRC_RANGE=60000,61000
export GLOBUS_TCP_PORT_RANGE=60000,61000
Yadu
On 07/14/2015 12:02 PM, Aurélien Mazurie wrote:
> Thanks, that is extremely helpful!
> A quick question: I fail to deploy the bootstrap JAR to the remote machines because Swift is grabbing a hostname that is incorrect on my local machine. I thought that the 'hostName' property would fix this, but it doesn't. Is there a way to set the hostname that will be used by the remote machine to download the bootstrap JAR file?
> Best,
> Aurélien
More information about the Swift-user mailing list
