[Swift-user] walltime in sites does not match the walltime of submitted job
Michael Wilde
wilde at anl.gov
Sat Jan 31 11:50:19 CST 2015
MaxWallTime is the estimate/ceiling you provide Swift for your app tasks
for this site.
I think that if you don't specify a MaxTime (which puts an upper bound
on the wall time of the scheduler jobs which Swift/coasters will submit)
then Swift uses what's in its ready-to-run task queue to determine the
scheduler job walltime.
If you want shorter jobs (e.g. to not wait so long in the queue) then
you should un-comment your maxtime tag in the sites entry and set it to
what you want to see. Be aware that you need to consider what your
likely app task time will really be as you try to balance these two time
limits.
- Mike
On 1/31/15 11:44 AM, Ketan Maheshwari wrote:
> Hi,
> On Blues, I submit a script with the following sites spec:
> <?xml version="1.0" encoding="UTF-8"?>
> <config xmlns="http://www.ci.uchicago.edu/swift/SwiftSites">
> <pool handle="blues">
> <execution provider="coaster" jobmanager="local:pbs"/>
> <filesystem provider="local" url="none" />
> <!-- <profile namespace="globus" key="maxtime">2040</profile>-->
> <profile namespace="globus" key="maxWalltime">03:40:00</profile>
> <profile namespace="globus" key="jobsPerNode">1</profile>
> <profile namespace="globus" key="slots">1</profile>
> <profile namespace="globus" key="ppn">2</profile>
> <profile namespace="globus" key="jobtype">single</profile>
> <profile namespace="globus" key="nodeGranularity">16</profile>
> <profile namespace="globus" key="maxnodes">16</profile>
> <profile namespace="karajan" key="jobThrottle">2.20</profile>
> <profile namespace="karajan" key="initialScore">10000</profile>
> <!-- <profile namespace="globus" key="keepSiteDir">true</profile>-->
> <workdirectory>/home/ketan/swift.workdir</workdirectory>
> </pool>
> The maxWalltime being 3 hours 40 minutes. However, the job that gets
> submitted is with 11 hours of walltime:
> $ qstat
> bmgt1.lcrc.anl.gov <http://bmgt1.lcrc.anl.gov>:
> Req'd Req'd Elap
> Job ID Username Queue Jobname SessID NDS TSKS Memory
> Time S Time
> 851234.bmgt1.l ketan batch B0131-3911 -- 16 32 -- 11:00
> Q --
> Any clues?
> Thanks,
> Ketan
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
Michael Wilde
Mathematics and Computer Science Computation Institute
Argonne National Laboratory The University of Chicago
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20150131/feaa262b/attachment.html>
More information about the Swift-user
