[Swift-user] Swift-Java error: Block task failed: Connection to worker lost
Karthikeyan Balasubramanian
karthikeyanb at uchicago.edu
Fri Jan 23 19:47:43 CST 2015
I am encountering the following error and subsequently Swift fails. The code runs and generates results for a while and then throws up this error. Browsing the swift-user forum, it appears that the issue is not completely new. But, I am unable to identify a suitable solution.
Caused by:
java.io.IOException: Broken pipe
at sun.nio.ch.FileDispatcherImpl.write0(Native Method)
at sun.nio.ch.SocketDispatcher.write(SocketDispatcher.java:47)
at sun.nio.ch.IOUtil.writeFromNativeBuffer(IOUtil.java:93)
at sun.nio.ch.IOUtil.write(IOUtil.java:65)
at sun.nio.ch.SocketChannelImpl.write(SocketChannelImpl.java:487)
at org.globus.cog.karajan.workflow.service.channels.NIOSender.write(NIOSender.java:168)
at org.globus.cog.karajan.workflow.service.channels.NIOSender.run(NIOSender.java:133)
B.K.
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20150124/dc1049f6/attachment.html>
More information about the Swift-user
