[Swift-user] trunk error when using two pools
Ketan Maheshwari
ketan at mcs.anl.gov
Sat Jan 3 14:37:30 CST 2015
I am trying to run a Swift script with two apps each with a different
configuration in terms of job size. For this, I am using two different
pools in the conf. At runtime, however, I get the following error:
Execution failed:
Exception in wrf:
Arguments: []
Host: edison2
Directory: wf.edison-run002/jobs/w/wrf-jjtyam2m
exception @ swift-int-staging.k, line: 165
Caused by:
exception @ swift-int-staging.k, line: 160
Caused by: null
Caused by:
org.globus.cog.abstraction.impl.common.task.TaskSubmissionException: Could
not submit job
Caused by: org.globus.cog.coaster.ProtocolException:
java.lang.IllegalStateException: A channel already exists for this key: null
@id://2
Caused by: org.globus.cog.coaster.RemoteException:
@id://2
Caused by: java.lang.IllegalStateException: A channel already exists for
this key: null at id://2
at
org.globus.cog.coaster.channels.ChannelManager.registerChannel(ChannelManager.java:128)
at
org.globus.cog.coaster.channels.ChannelManager.registerChannel(ChannelManager.java:140)
at
org.globus.cog.coaster.channels.ChannelManager.registerChannel(ChannelManager.java:136)
at
org.globus.cog.abstraction.coaster.service.ServiceConfigurationHandler.requestComplete(ServiceConfigurationHandler.java:50)
at
org.globus.cog.coaster.handlers.RequestHandler.receiveCompleted(RequestHandler.java:112)
at
org.globus.cog.coaster.channels.AbstractCoasterChannel.handleRequest(AbstractCoasterChannel.java:590)
at
org.globus.cog.coaster.channels.AbstractPipedChannel.actualSend(AbstractPipedChannel.java:101)
at
org.globus.cog.coaster.channels.AbstractPipedChannel$Sender.run(AbstractPipedChannel.java:130)
The rundir for this run, which is on a cray (nersc edison) is attached.
Thanks for any suggestions,
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20150103/0947dc27/attachment.html>
Type: application/x-gzip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20150103/0947dc27/attachment.bin>
More information about the Swift-user
