[Swift-user] Swift runs one task despite slots set to higher number
Mihael Hategan
hategan at mcs.anl.gov
Sun Feb 1 20:57:31 CST 2015
You are asking for 16 cores through granularity, but explicitly setting
jobType=single. This results PBS only attempting to start one worker for
each job. However, the coaster scheduler thinks that 16 workers were
requested and, since that is more than the number of queued jobs, it
will not start any other ones.
Mihael
On Sun, 2015-02-01 at 20:09 -0600, Ketan Maheshwari wrote:
> Hi Mihael,
> The run is not yet finished. Please find attached the log so far.
> Thanks,
> Ketan
> On Sun, Feb 1, 2015 at 8:04 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> > Hi,
> > Can you post the swift log please?
> > Mihael
> > On Sun, 2015-02-01 at 19:58 -0600, Ketan Maheshwari wrote:
> > > Hi,
> > > Running a workflow, I need to run 10 PBS tasks each with a size of 16
> > > nodes.
> > > The workflow starts with 4 single task stages and then fans out to a
> > > foreach loop with 10 tasks.
> > > Here is the sites file I am using:
> > > <?xml version="1.0" encoding="UTF-8"?>
> > > <config xmlns="http://www.ci.uchicago.edu/swift/SwiftSites">
> > > <pool handle="blues">
> > > <execution provider="coaster" jobmanager="local:pbs"/>
> > > <filesystem provider="local" url="none" />
> > > <profile namespace="globus" key="maxtime">13400</profile>
> > > <profile namespace="globus" key="maxWalltime">03:41:00</profile>
> > > <profile namespace="globus" key="jobsPerNode">1</profile>
> > > <profile namespace="globus" key="slots">10</profile>
> > > <profile namespace="globus" key="ppn">2</profile>
> > > <profile namespace="globus" key="jobtype">single</profile>
> > > <profile namespace="globus" key="nodeGranularity">16</profile>
> > > <profile namespace="globus" key="maxnodes">16</profile>
> > > <profile namespace="karajan" key="jobThrottle">2.20</profile>
> > > <profile namespace="karajan" key="initialScore">10000</profile>
> > > <!-- <profile namespace="globus" key="keepSiteDir">true</profile>-->
> > > <workdirectory>/home/ketan/swift.workdir</workdirectory>
> > > </pool>
> > > <pool handle="localhost">
> > > <execution provider="coaster" jobmanager="local:local" />
> > > <profile namespace="globus" key="slots">1</profile>
> > > <profile namespace="karajan" key="jobThrottle">2.06</profile>
> > > <profile namespace="globus" key="jobsPerNode">3</profile>
> > > <profile namespace="globus" key="maxtime">9700</profile>
> > > <profile namespace="globus" key="maxWalltime">02:39:00</profile>
> > > <profile namespace="globus" key="walltime">10060</profile>
> > > <profile namespace="globus" key="maxnodes">1</profile>
> > > <profile namespace="globus" key="nodegranularity">1</profile>
> > > <filesystem provider="local"/>
> > > </pool>
> > > </config>
> > > However, Swift runs only 1 task throughout the workflow even after
> > reaching
> > > the foreach loop.
> > > Any suggestions?
> > > Thanks,
> > > Ketan
> > > _______________________________________________
> > > Swift-user mailing list
> > > Swift-user at ci.uchicago.edu
> > > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
More information about the Swift-user
