[Swift-user] installing swift on aws
    Justin M Wozniak
    wozniak at mcs.anl.gov
    Mon Aug 10 15:43:14 CDT 2015
Hi
     Is this on Ubuntu?
     Justin
On 08/10/2015 03:18 PM, Jonathan S Burge wrote:
> Currently I am trying to install swift-t on an instance of Amazon's
> Web Services. I am trying to install swift manually. The c-utils and
> adlb packages have compiled successfully, however, I am now having
> issues with turbine. Running ./configure and make seem to be
> functioning, but when make install is attempted, no directory is
> created and the user is prompted for another command without and
> verbose output.
> This is my command line for ./configure
> ./configure --prefix=/home/ubuntu/sfw/swift-t/turbine
> --with-adlb=$HOME/sfw/swift-t/lb --with-hdf5=no --enable-python=yes
> Running make check_includes shows that several things are not present,
> including mpi and python.
> However, I have already installed these and they make be either called
> or accessed through various commands.
> ex) python (opens python)
>      mpichversion (returns version 3.0.4)
> If someone has advice or solutions to this problem, that would be
> greatly appreciated. Thanks.
> Jonathan
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
Justin M Wozniak
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20150810/9739a592/attachment.html>
More information about the Swift-user
