[Swift-user] Error with SSH and SSH-CL
Yadu Nand
yadudoc1729 at gmail.com
Thu Apr 2 19:00:01 CDT 2015
Hi Justin,
Could you send me a tarball of the configs and the log files generated ?
Meanwhile, could you try the configs from the test-suite for the MCS
systems ?
https://github.com/swift-lang/swift-k/tree/release-0.95-swift/tests/sites/mcs
You would need the sites.template.xml, swift.properties and
tc.template.data.
Yadu
On Mon, Mar 30, 2015 at 4:10 PM, Scherer, Justin C. <jscherer at anl.gov>
wrote:
> I have been trying to get the simple hello.swift script to run on a remote
> host that I have set up with another researcher. I will post my sites.xml,
> config file, and tc.data files along with this message. After going through
> all of the steps to get ssh to work, I get the following error for running
> it in ssh mode:
> RunID: 20150330-1550-ut0jr8rf
> Progress: time: Mon, 30 Mar 2015 15:50:36 -0500
> Execution failed:
> Could not initialize shared directory on remotehost
> Caused by:
> org.globus.cog.abstraction.impl.file.FileResourceException: Error
> while communicating with the SSH server on 146.137.66.189:22
> Caused by:
> Invalid private key or passphrase
> Caused by:
> Can't read key due to cryptography problems:
> java.security.NoSuchAlgorithmException: Unsupported passphrase algorithm:
> AES-128-CBC
> greeting, hello.swift, line 9
> I tried both the dsa algorithm and putting in the rsa algorithm for this.
> Here is my sites.xml for this:
> <config>
> <pool handle="remotehost">
> <execution provider="coaster" jobmanager="ssh:local" url="<blanked out
> for obvious reasons>"/>
> <filesystem provider="ssh" url="146.137.66.189"/>
> <profile namespace="karajan" key="jobThrottle">0</profile>
> <profile namespace="karajan" key="initialScore">10000</profile>
> <workdirectory>/home/swift-user/temp</workdirectory>
> </pool>
> </config>
> also, here is the tc.data file:
> #This is the transformation catalog.
> #It comes pre-configured with a number of simple transformations with
> #paths that are likely to work on a linux box. However, on some systems,
> #the paths to these executables will be different (for example, sometimes
> #some of these programs are found in /usr/bin rather than in /bin)
> #NOTE WELL: fields in this file must be separated by tabs, not spaces; and
> #there must be no trailing whitespace at the end of each line.
> # sitename transformation path INSTALLED platform profiles
> localhost echo /bin/echo INSTALLED INTEL32::LINUX
> null
> localhost cat /bin/cat INSTALLED INTEL32::LINUX
> null
> localhost ls /bin/ls INSTALLED INTEL32::LINUX
> null
> localhost grep /bin/grep INSTALLED INTEL32::LINUX
> null
> localhost sort /bin/sort INSTALLED INTEL32::LINUX
> null
> localhost paste /bin/paste INSTALLED INTEL32::LINUX
> null
> localhost cp /bin/cp INSTALLED INTEL32::LINUX
> null
> localhost touch /bin/touch INSTALLED INTEL32::LINUX
> null
> localhost wc /usr/bin/wc INSTALLED INTEL32::LINUX
> null
> localhost sleep /bin/sleep null null null
> remotehost echo /bin/echo INSTALLED INTEL32::LINUX
> null
> and the configuration file is exactly like what is shown in the
> documentation.
> If I try to do the ssh-cl interface, I get the following error:
> RunID: 20150330-1529-4b3sr1u4
> Progress: time: Mon, 30 Mar 2015 15:29:20 -0500
> Execution failed:
> Exception in echo:
> Arguments: [Hello, world!]
> Host: remotehost
> Directory: hello-20150330-1529-4b3sr1u4/jobs/c/echo-c3z4un6m
> Caused by:
> Could not submit job
> Caused by:
> Could not start coaster service
> Caused by:
> java.lang.NullPointerException
> at
> org.globus.cog.abstraction.impl.execution.coaster.AutoCA.ensureCACertsExist(AutoCA.java:143)
> at
> org.globus.cog.abstraction.impl.execution.coaster.AutoCA.createProxy(AutoCA.java:128)
> at
> org.globus.cog.abstraction.impl.execution.coaster.ServiceManager.setupGSIProxy(ServiceManager.java:238)
> at
> org.globus.cog.abstraction.impl.execution.coaster.ServiceManager.startService(ServiceManager.java:194)
> at
> org.globus.cog.abstraction.impl.execution.coaster.ServiceManager.reserveService(ServiceManager.java:132)
> at
> org.globus.cog.abstraction.impl.execution.coaster.ServiceManager.reserveService(ServiceManager.java:151)
> at
> org.globus.cog.abstraction.impl.execution.coaster.JobSubmissionTaskHandler.getChannel(JobSubmissionTaskHandler.java:119)
> at
> org.globus.cog.abstraction.impl.execution.coaster.JobSubmissionTaskHandler.submit(JobSubmissionTaskHandler.java:105)
> at
> org.globus.cog.abstraction.impl.common.AbstractTaskHandler.submit(AbstractTaskHandler.java:45)
> at
> org.globus.cog.karajan.scheduler.submitQueue.NonBlockingSubmit.run(NonBlockingSubmit.java:97)
> at
> java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471)
> at java.util.concurrent.FutureTask.run(FutureTask.java:262)
> at
> java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
> at
> java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
> at java.lang.Thread.run(Thread.java:745)
> There is no shared folder, so I have to use scheduling.
> I am using Swift version 0.94.1 from the main website. Any help is
> appreciated. Thank you!
> Justin Scherer
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
Yadu Nand B
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20150402/bf2df6e4/attachment.html>
More information about the Swift-user
