[Swift-user] problem with running coaster
Justin bbt
justinbbt at gmail.com
Fri Sep 19 20:48:48 CDT 2014
Hi all
I have a problem in running swift over the cloud of Microsoft Azure. I have
two nodes on the cloud. I installed swift on one of them and I can run
part01-03 locally successfully. I am trying to use the coaster to run
part04-part-6 on the other node. Here is the output I get for "swift
p4.swift"
Swift 0.95 RC6 swift-r7900 cog-r3908
RunID: run005
Warning: The @ syntax for function invocation is deprecated
Progress: Sat, 20 Sep 2014 01:36:02+0000
Exception in thread "Scheduler" java.lang.NullPointerException
at
org.globus.cog.abstraction.impl.common.task.TaskImpl.hashCode(TaskImpl.java:364)
at java.util.HashMap.hash(HashMap.java:338)
at java.util.HashMap.get(HashMap.java:556)
at
org.griphyn.vdl.karajan.VDSAdaptiveScheduler.failTask(VDSAdaptiveScheduler.java:400)
at
org.globus.cog.karajan.scheduler.LateBindingScheduler.run(LateBindingScheduler.java:266)
Progress: Sat, 20 Sep 2014 01:36:03+0000 Selecting site:10
No events in 1s.
Finding dependency loops...
Waiting threads:
Thread: R-6, waiting on sims (declared on line 21)
swift:execute, p4, line 96
analyze, p4, line 211
Thread: R-5-2-3, waiting on simout (declared on line 24)
assignment, p4, line 28
Thread: R-5-7-3, waiting on simout (declared on line 24)
Thread: R-5-8-3, waiting on simout (declared on line 24)
Thread: R-5-9-3, waiting on simout (declared on line 24)
Thread: R-5-3x2, waiting on simout (declared on line 24)
Thread: R-5-0-3, waiting on simout (declared on line 24)
Thread: R-5-1-3, waiting on simout (declared on line 24)
Thread: R-5-6-3, waiting on simout (declared on line 24)
Thread: R-5-4-3, waiting on simout (declared on line 24)
Thread: R-5x2-3, waiting on simout (declared on line 24)
No dependency loops found.
The following threads are independently hung:
Irrecoverable error found. Exiting.
This is the content of my coaster-service.conf
export WORKER_LOCATION=.
export WORKER_HOSTS="191.238.1.187"
export WORKER_MODE=ssh
export WORKER_USERNAME=azureuser
export IPADDR=191.238.1.33
export WORKER_LOG_DIR=.
export WORK=/home/ubuntu/work
export JOBSPERNODE=1
export JOBTHROTTLE=10
export SSH_TUNNELING=yes
And here is the content of start-coaster-service.log
Running /home/azureuser/swift-0.95-RC6/bin/coaster-service -nosec -portfile
/tmp/tmp.8WkG0mKKzo -localportfile /tmp/tmp.hZvsxQd5J1 -passive
Switching log to: cps-2014-09-20_01-21-41.log
2014-09-20 01:21:41,305+0000 WARN CoasterPersistentService Switching log
Local contacts: [http://100.74.60.3:55071]
2014-09-20 01:21:41,338+0000 INFO Settings Local contacts: [
Starting... id=0920-2101410
2014-09-20 01:21:41,350+0000 INFO BlockQueueProcessor Starting...
id=0920-2101410
Started local service: http://100.74.60.3:55071
2014-09-20 01:21:41,350+0000 INFO CoasterService Started local service:
Started coaster service: http://100.74.60.3:42972
2014-09-20 01:21:41,351+0000 INFO CoasterService Started coaster service:
Worker connection URL: http://100.74.60.3:55071
Running ssh -N -T -R *:55071:localhost:55071 azureuser at 191.238.1.187
Running ssh azureuser at 191.238.1.187 mkdir -p . && mkdir -p .
Running scp /home/azureuser/swift-0.95-RC6/bin/worker.pl
azureuser at 191.238.1.187:.
Running ssh azureuser at 191.238.1.187 WORKER_LOGGING_LEVEL= nohup ./worker.pl
http://191.238.1.33:55071 191.238.1.187 . &> /dev/null &
HeapMax: 13134987264, CrtHeap: 886571008, UsedHeap: 41712768
2014-09-20 01:21:51,356+0000 INFO CoasterService HeapMax: 13134987264,
2014-09-20 01:22:01,364+0000 INFO CoasterService HeapMax: 13134987264,
I had this problem before with my laptop connecting to a remote server and Yadu
Nand Babuji told me it is because I don't have a public ip.
But, I have the problem again now with my nodes in the cloud having the
public ip.
Though as can be seen in the log, during the connection coaster uses the
private ip
(100.74.60.3)
Is this really a problem with public IP?
Does anybody know how to solve this problem ?
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140919/2661c54d/attachment.html>
More information about the Swift-user
