[Swift-user] Bus Error
Mihael Hategan
hategan at mcs.anl.gov
Thu Sep 4 14:28:50 CDT 2014
Hi Jonathan,
It's a bus error, which is just slightly worse than a segfault. both of
which would reflect bugs in the JVM.
Was there a hs_err_pid???.log produced? It might help.
Also, it might help to know the exact version of java as well as the
hardware details.
Mihael
On Thu, 2014-09-04 at 10:44 -0500, Jonathan Ozik wrote:
> Hi all,
> I’m trying to launch a large number of runs, 16807 to be precise, and am running into a couple of issues.
> The first issue was a Java heap out of memory exception. I looked around to see where the best place to increase the max heap would be, and I settled on line 13 (“HEAPMAX=4096M”) of the swift executable. I should mention that all of this is using swift-0.95-RC6.
> That did get rid of the out of memory exception, but this time I got a Bus error:
> /home/ozik/swift_dist/swift-0.95-RC6/bin/swift: line 188: 108521 Bus error (core dumped) java -Xmx4096M -XX:+HeapDumpOnOutOfMemoryError -Djava.endorsed.dirs=/home/ozik/swift_dist/swift-0.95-RC6/lib/endorsed -DUID=5702 -DGLOBUS_HOSTNAME=blogin3 -DCOG_INSTALL_PATH=/home/ozik/swift_dist/swift-0.95-RC6 -Dswift.home=/home/ozik/swift_dist/swift-0.95-RC6 -Djava.security.egd=file:///dev/urandom -Dscript.dir=/lcrc/project/gcmat/runs/heatmap7_7x7/complete_model/run003/scripts -Drestart.log.name=/lcrc/project/gcmat/runs/heatmap7_7x7/complete_model/run003/restart.log -Ddebug.dir.prefix=run003/ -classpath /home/ozik/swift_dist/swift-0.95-RC6/etc:/home/ozik/swift_dist/swift-0.95-RC6/libexec:/home/ozik/swift_dist/swift-0.95-RC6/lib/ant.jar:/home/ozik/swift_dist/swift-0.95-RC6/lib/antlr-2.7.5.jar:/home/ozik/swift_dist/swift-0.95-RC6/lib/castor-0.9.6.jar:/home/ozik/swift_dist/swift-0.95-RC6/lib/coaster-bootstrap.jar:/home/ozik/swift_dist/swift-0.95-RC6/lib/cog-abstraction-common-2.4.jar:/home/ozik/swift_dist/swift-0.95-RC6/lib/cog-grapheditor-0.47.jar:/home/ozik/swift_dist/swift-0.95-RC6/lib/cog-jglobus-1.7.0.jar:/home/ozik/swift_dist/swift-0.95-RC6/lib/cog-karajan-0.36-dev.jar:/home/ozik/swift_dist/swift-0.95-RC6/lib/cog-provider-coaster-0.3.jar:/home/ozik/swift_dist/swift-0.95-RC6/lib/cog-provider-dcache-0.1.jar:/home/ozik/swift_dist/swift-0.95-RC6/lib/cog-provider-gt2-2.4.jar:/home/ozik/swift_dist/swift-0.95-RC6/lib/cog-provider-local-2.2.jar:/home/ozik/swift_dist/swift-0.95-RC6/lib/cog-provider-localscheduler-0.4.jar:/home/ozik/swift_dist/swift-0.95-RC6/lib/cog-provider-ssh-2.4.jar:/home/ozik/swift_dist/swift-0.95-RC6/lib/cog-provider-webdav-2.1.jar:/home/ozik/swift_dist/swift-0.95-RC6/lib/cog-resources-1.0.jar:/home/ozik/swift_dist/swift-0.95-RC6/lib/cog-swift-svn.jar:/home/ozik/swift_dist/swift-0.95-RC6/lib/cog-util-0.92.jar:/home/ozik/swift_dist/swift-0.95-RC6/lib/commons-httpclient.jar:/home/ozik/swift_dist/swift-0.95-RC6/lib/commons-logging-1.1.jar:/home/ozik/swift_dist/swift-0.95-RC6/lib/cryptix32.jar:/home/ozik/swift_dist/swift-0.95-RC6/lib/cryptix-asn1.jar:/home/ozik/swift_dist/swift-0.95-RC6/lib/cryptix.jar:/home/ozik/swift_dist/swift-0.95-RC6/lib/j2ssh-common-0.2.2.jar:/home/ozik/swift_dist/swift-0.95-RC6/lib/j2ssh-core-0.2.2-patch-b.jar:/home/ozik/swift_dist/swift-0.95-RC6/lib/jakarta-regexp-1.2.jar:/home/ozik/swift_dist/swift-0.95-RC6/lib/jakarta-slide-webdavlib-2.0.jar:/home/ozik/swift_dist/swift-0.95-RC6/lib/jaxrpc.jar:/home/ozik/swift_dist/swift-0.95-RC6/lib/jce-jdk13-131.jar:/home/ozik/swift_dist/swift-0.95-RC6/lib/jcommon-1.0.18.jar:/home/ozik/swift_dist/swift-0.95-RC6/lib/jfreechart-1.0.15.jar:/home/ozik/swift_dist/swift-0.95-RC6/lib/jgss.jar:/home/ozik/swift_dist/swift-0.95-RC6/lib/jline-0.9.94.jar:/home/ozik/swift_dist/swift-0.95-RC6/lib/jsr173_1.0_api.jar:/home/ozik/swift_dist/swift-0.95-RC6/lib/jug-lgpl-2.0.0.jar:/home/ozik/swift_dist/swift-0.95-RC6/lib/junit.jar:/home/ozik/swift_dist/swift-0.95-RC6/lib/log4j-1.2.16.jar:/home/ozik/swift_dist/swift-0.95-RC6/lib/puretls.jar:/home/ozik/swift_dist/swift-0.95-RC6/lib/resolver.jar:/home/ozik/swift_dist/swift-0.95-RC6/lib/stringtemplate.jar:/home/ozik/swift_dist/swift-0.95-RC6/lib/vdldefinitions.jar:/home/ozik/swift_dist/swift-0.95-RC6/lib/xbean.jar:/home/ozik/swift_dist/swift-0.95-RC6/lib/xbean_xpath.jar: org.griphyn.vdl.karajan.Loader -runid run003 -logfile /lcrc/project/gcmat/runs/heatmap7_7x7/complete_model/run003/run003.log -sites.file /lcrc/project/gcmat/runs/heatmap7_7x7/complete_model/run003/sites.xml -tc.file /lcrc/project/gcmat/runs/heatmap7_7x7/complete_model/run003/apps -config /lcrc/project/gcmat/runs/heatmap7_7x7/complete_model/run003/cf repast.swift -lines=823543 -inst=16807 -upf=unrolledParamFile.txt
> Any ideas on this?
> Jonathan
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
More information about the Swift-user
