[Swift-user] Swift: ConnectException: Connection refused Issue
Gagan Munisiddha Gowda
ggowda at hawk.iit.edu
Sat Oct 25 20:42:50 CDT 2014
Hi Ajay,
Could you try restarting your entire cluster. (terminate and start )
This happens occasionally for some unknown reason.
Gagan
On 26/10/2014 7:05 am, "Ajay Anthony" <aanthon2 at hawk.iit.edu> wrote:
> Hi Swift users,
> Kindly help me in below issue. Stuck on this issue almost whole day.
> I am trying to run swift word.swift on headnode in aws and have 1
> worker running.
> 2014-10-26 01:17:52,685+0000 INFO AbstractCoasterChannel
> TCPChannel[client, http://127.0.0.1:50010] setting name to
> 2014-10-26 01:17:52,709+0000 INFO Execute TASK_STATUS_CHANGE
> taskid=urn:R-0-1414286270539 status=1
> 2014-10-26 01:17:52,712+0000 INFO LateBindingScheduler jobs queued: 0
> 2014-10-26 01:17:52,712+0000 DEBUG swift APPLICATION_EXCEPTION
> jobid=bash-lupsjczl - Application exception: null
> *Caused by:
> org.globus.cog.abstraction.impl.common.task.TaskSubmissionException: Could
> not submit jobCaused by: org.globus.cog.coaster.channels.ChannelException:
> Failed to create socketCaused by: java.net.ConnectException: Connection
> refused*
> Below are my configuratioins:
> swift.conf:
> sites: cloud-static
> site.cloud-static {
> execution {
> type:"coaster-persistent"
> URL: "http://127.0.0.1:50010"
> jobManager: "local:local"
> options {
> maxJobs: 10
> tasksPerNode: 2
> initialParallelTasks: 20
> maxParallelTasks: 20
> filesystem.type: local
> workDirectory: /tmp/swiftwork
> staging: local
> app.ALL {executable: "*"}
> Below is the Swift version I am using:
> ubuntu at ip-172-31-17-186:~/cloud-tutorials/swift-cloud-tutorial/word_count$
> swift -version
> Swift trunk git-rev: 2d334140f2c288e5aeb3d354de0ecda35b4b3aac heads/master
> 6130 (modified locally)
> I am able to run with "sites: local" successfully , but failing with
> "sites: cloud-static".
> Please suggest on what can be the issue.
> Thanks and Regards,
> AJay ANthony.
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20141026/986f769a/attachment.html>
More information about the Swift-user
