[Swift-user] CS553: Stuck with Swift "bash application not available" issue . Please suggest
Yadu Nand
yadudoc1729 at gmail.com
Thu Oct 23 21:50:46 CDT 2014
Hi Ajay,
As Mihael pointed out, you are using the wrong swift version for the
tutorials you are running.
Please try the following steps on the headnode instance:
cd /home/ubuntu/cloud-tutorials/swift-cloud-tutorial/
source setup.sh
swift -version
The swift version should output something like the following :
Swift trunk git-rev: 2d334140f2c288e5aeb3d354de0ecda35b4b3aac heads/master
If that is what you see, please retry the tutorials.
-Yadu
On Thu, Oct 23, 2014 at 9:46 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> Hi,
> You have some version mismatch there.
> > swift -version
> > Swift 0.94.1 swift-r7114 cog-r3803
> However, the swift configuration format that you are using (swift.conf),
> is only available in trunk, and that is two versions above 0.94.
> So the question is how you got that swift version, and why that
> particular version.
> Mihael
> On Thu, 2014-10-23 at 21:59 -0400, Ajay Anthony wrote:
> > Hi Swift Users,
> > Please help me with below issue. I am stuck on this since 2 days.
> > I am trying to run split.sh script through word.swift file, which will
> > split a file in 16 chunks.
> > split.sh:
> > #! /bin/bash
> > split -a 2 -d -n 16 small-dataset
> /home/ajay/CS553/Ass_2/Swift/cloud-tutorials/swift-cloud-tutorial/cloud-cat/input/small-dataset
> > word.swift:
> > type file;
> > app (file out) split (file script)
> > bash @script stdout=@filename(out);
> > file script_file <"*split.sh*">;
> > file output;
> > output = split(script_file);
> > I am facing the below issue:
> > RunID: 20141023-2145-ur5u9gpa
> > Progress: time: Thu, 23 Oct 2014 21:45:55 -0400
> > Execution failed:
> > The application "bash" is not available for any site/pool in your
> > tc.data catalog
> > split, word.swift, line 10
> > The script version I am using is :
> > ajay at ubuntu
> :~/CS553/Ass_2/Swift/cloud-tutorials/swift-cloud-tutorial/cloud-cat$
> > swift -version
> > My swift.conf file has below configurations:
> > sites: local
> > site.local {
> > filesystem {
> > type: "local"
> > URL: "localhost"
> > execution {
> > type: "local"
> > URL: "localhost"
> > workDirectory: /tmp/${env.USER}
> > maxParallelTasks: 32
> > initialParallelTasks: 31
> > app.ALL {executable: "*"}
> > Thanks in Advance.
> > Regards,
> > Ajay Anthony,
> > _______________________________________________
> > Swift-user mailing list
> > Swift-user at ci.uchicago.edu
> > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
Yadu Nand B
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20141023/2baf395e/attachment.html>
More information about the Swift-user
