[Swift-user] sort on large data
Yadu Nand Babuji
yadunand at uchicago.edu
Mon Oct 20 20:03:11 CDT 2014
@Jiada, Dongfang,
I've updated the README on the
https://github.com/yadudoc/cloud-tutorials page with documentation on
how to use
s3fs as a shared filesystem. I've added configs and links to external
documentation. Please try it, and let me know
if any of it is unclear or buggy.
I would also appreciate help from anyone in testing this.
@Gagan,
That was most likely a bug in my scripts, where the user script is
executed ahead of the installation of s3fs on the worker nodes.
Please try again, and if you see the same behavior, please let me know.
Yadu
On 10/19/2014 12:08 AM, Gagan Munisiddha Gowda wrote:
> Hi Yadu,
> I am in the same direction where I am trying to use a shared file
> system (S3 bucket / S3FS).
> I have setup : /WORKER_INIT_SCRIPT=/path/to/mounts3fs.sh in
> cloud-tutorials/ec2/configs//(as mentioned in the tutorials)/
> Though i am able to setup the passwd-s3fs file in the desired location
> (using mounts3fs.sh script), i see that the S3 bucket is not getting
> mounted.
> I have verified the passwd-s3fs file and mount point and all seems to
> be created as expected. But, one observation was the owner of these
> files were 'root' user as it was getting created through the setup.sh.
> So, i added more commands to change the permissions and made 'ubuntu'
> as the owner for all related files.
> Even after all these changes, i see that the S3 bucket is still not
> mounted.
> *PS: If i connect to the workers and run the s3fs command manually, it
> does mount !*
> sudo s3fs -o allow_other,gid=1000,use_cache=/home/ubuntu/cache
> <my-bucket> <mount-point>;
> (tried with and without sudo)
> Thanks for your help.
> On Sun, Oct 19, 2014 at 4:43 AM, Yadu Nand Babuji
> <yadunand at uchicago.edu <mailto:yadunand at uchicago.edu>> wrote:
> Hi Jiada Tu,
> 1) Here's an example for returning an array of files :
> type file;
> app (file outs[]) make_outputs (file script)
> bash @script;
> file outputs[] <filesys_mapper; prefix="outputs">;
> file script <"make_outputs.sh">; # This script creates a few
> files with outputs as prefix
> (outputs) = make_outputs(script);
> 2) The products of a successful task execution, must be visible to
> the headnode (where swift runs) either through a
> - shared filesystem (NFS, S3 mounted over s3fs etc) or
> - must be brought back over the network.
> But, we can reduce the overhead in moving the results to the
> headnode and then to the workers for the reduce stage.
> I understand that this is part of your assignment, so I will try
> to answer without getting too specific, at the same time,
> concepts from hadoop do not necessarily work directly in this
> context. So here are some things to consider to get
> the best performance possible:
> - Assuming that the texts contain 10K unique words, your sort
> program will generate a file containing atmost 10K lines
> (which would be definitely under an MB). Is there any advantage
> into splitting this into smaller files ?
> - Since the final merge involves tiny files, you could very well
> do the reduce stage on the headnode and be quite efficient
> (you can define the reduce app only for site:local)
> sites : [local, cloud-static]
> site.local {
> app.reduce {
> executable : ${env.PWD}/reduce.py
> site.cloud-static {
> app.python {
> executable : /usr/bin/python
> This assumes that you are going to define your sorting app like
> this :
> app (file freqs) sort (file sorting_script, file input ) {
> python @sorting_script @input;
> - The real cost is in having the original text reach the workers,
> this can be made faster by :
> - A better headnode with better network/disk IO (I've measured
> 140Mbit/s between m1.medium nodes, c3.8xlarge comes with 975Mbits/s)
> - Use S3 with S3fs and have swift-workers pull data from S3
> which is pretty scalable, and remove the IO load from the headnode.
> - Identify the optimal size for data chunks for your specific
> problem. Each chunk of data in this case comes with the overhead
> of starting
> a new remote task, sending the data and bringing results back.
> Note that the result of a wordcount on a file whether it is 1Mb or
> 10Gb
> is still the atmost 1Mb (with earlier assumptions)
> - Ensure that the data with the same datacenter, for cost as well
> as performance. By limiting the cluster to US-Oregon we already do
> this.
> If you would like to attempt this using S3FS, let me know, I'll be
> happy to explain that in detail.
> Thanks,
> Yadu
> On 10/18/2014 04:18 PM, Jiada Tu wrote:
>> I am doing an assignment with swift to sort large data. The data
>> contains one record (string) each line. We need to sort the
>> records base on ascii code. The data is too large to fit in the
>> memory.
>> The large data file is in head node, and I run the swift script
>> directly on head node.
>> Here's what I plan to do:
>> 1) split the big file into 64MB files
>> 2) let each worker task sort one 64MB files. Say, each task will
>> call a "sort.py" (written by me). sort.py will output a list of
>> files, say:"sorted-worker1-001; sorted-worker1-002; ......". The
>> first file contains the records started with 'a', the second
>> started with 'b', etc.
>> 3) now we will have all records started with 'a' in
>> (sorted-worker1-001;sorted-worker2-001;...); 'b' in
>> (sorted-worker1-002;sorted-worker2-002; ......); ...... Then I
>> send all the files contains records 'a' to a "reduce" worker task
>> and let it merge these files into one single file. Same to 'b',
>> 'c', etc.
>> 4) now we get 26 files (a-z) with each sorted inside.
>> Basically what I am doing is simulate Map-reduce. step 2 is map
>> and step 3 is reduce
>> Here comes some problems:
>> 1) for step 2, sort.py need to output a list of files. How can
>> swift app function handles list of outputs?
>> app (file[] outfiles) sort (file[] infiles) {
>> sort.py // how to put out files here?
>> 2) As I know (may be wrong), swift will stage all the output file
>> back to the local disk (here is the head node since I run the
>> swift script directly on headnode). So the output files in step 2
>> will be staged back to head node first, then stage from head node
>> to the worker nodes to do the step 3, then stage the 26 files in
>> step 4 back to head node. I don't want it because the network
>> will be a huge bottleneck. Is there any way to tell the "reduce"
>> worker to get data directly from "map" worker? Maybe a shared
>> file system will help, but is there any way that user can control
>> the data staging between workers without using the shared file
>> system?
>> Since I am new to the swift, I may be totally wrong and
>> misunderstanding what swift do. If so, please correct me.
>> Swift-user mailing list
>> Swift-user at ci.uchicago.edu <mailto:Swift-user at ci.uchicago.edu>
>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
> Regards,
> Gagan
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20141020/37ef5b4a/attachment.html>
More information about the Swift-user
