[Swift-user] Fwd: Swift not running after restarting Amazon EC2 instance
Yadu Nand Babuji yadunand at uchicago.edu
Sat Oct 18 00:53:01 CDT 2014
Hi Sughosh,
Could you describe the steps you took to restart the the amazon instances ?
Did you restart the headnode instance and all the worker instances ?
I do not see anything in the logs that jump out.
-Yadu
On 10/18/2014 12:00 AM, Sughosh Divanji wrote:
> ---------- Forwarded message ----------
> From: *Sughosh Divanji* <sdivanji at hawk.iit.edu
> <mailto:sdivanji at hawk.iit.edu>>
> Date: Fri, Oct 17, 2014 at 11:50 PM
> Subject: Swift not running after restarting Amazon EC2 instance
> To: swift-user at ci.uchicago.edu <mailto:swift-user at ci.uchicago.edu>
> Cc: Raghav Kapoor <rkapoor7 at hawk.iit.edu
> <mailto:rkapoor7 at hawk.iit.edu>>, Arjun Nanjundappa
> <ananjun1 at hawk.iit.edu <mailto:ananjun1 at hawk.iit.edu>>
> Hi all,
> My name is Sughosh and I am a graduate student in CS from IIT Chicago.
> I am using swift for a homework assignment and facing this issue after
> restarting my amazon EC2 instances.
> root at ip-172-31-19-231:/home/ubuntu/wordcount# time swift wordcount.swift
> Swift trunk git-rev: 2d334140f2c288e5aeb3d354de0ecda35b4b3aac
> heads/master 6130 (modified locally)
> RunID: run004
> Progress: Sat, 18 Oct 2014 04:36:15+0000
> Progress: Sat, 18 Oct 2014 04:36:16+0000  Submitting:15  Failed but
> can retry:1
> Progress: Sat, 18 Oct 2014 04:36:46+0000  Submitting:15  Failed but
> can retry:1
> ^C
> real0m59.366s
> user0m4.248s
> sys0m0.373s
> The same code works fine without any issues before reboot. I have
> attached the run logs. Please let me know what could be the issue.
> Thanks,
> Sughosh
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20141018/64ee4570/attachment.html>
More information about the Swift-user mailing list
