[Swift-user] Error in running p4.swift in cloud-tutorials
Yadu Nand
yadudoc1729 at gmail.com
Fri Oct 17 18:16:01 CDT 2014
Hi Raghav,
I'm CC-ing the swift-user list, and encourage you to join the list.
I just tried this from scratch, and I'm not able to reproduce the issue you
are seeing. Could you send me
a tar ball of the runNNN folder, and the cps*log from your
/home/ubuntu/s3fs-fuse folder.
Yadu
On Fri, Oct 17, 2014 at 5:30 PM, Raghav Kapoor <rkapoor7 at hawk.iit.edu>
wrote:
> Hello Yadunand,
> My name is Raghav, I am a graduate student
> at IIT. I have an assignment on swift.
> I am using the directions provided on your github page.
> https://github.com/yadudoc/cloud-tutorials
> What I have observed is, all the sample tutorials were running a day
> before.
> But from yesterday, p4.swift is not running on the cloud.
> I am getting the following error which I am pasting below:
> root at ip-172-31-20-129:/home/ubuntu/swift-cloud-tutorial/part04# swift
> p4.swift
> Swift trunk git-rev: 2d334140f2c288e5aeb3d354de0ecda35b4b3aac heads/master
> 6130 (modified locally)
> RunID: run001
> Progress: Fri, 17 Oct 2014 22:10:33+0000
> Execution failed:
> Exception in sort:
> Arguments: [-n, unsorted.txt]
> Host: cloud-static
> Directory: p4-run001/jobs/0/sort-0abp6zyl
> exception @ swift-int-staging.k, line: 167
> Caused by: null
> Caused by:
> org.globus.cog.abstraction.impl.common.task.TaskSubmissionException: Could
> not submit job
> Caused by: org.globus.cog.coaster.channels.ChannelException: Failed to
> create socket
> Caused by: java.net.ConnectException: Connection refused
> k:assign @ swift.k, line: 171
> Caused by: Exception in sort:
> Host: cloud-static
> Caused by: null
> Caused by:
> not submit job
> create socket
> I think there is some problem with hostname and port numbers. it is not
> specified correctly.
> I see that you have updated the repository with some changes that might be
> the cause of this issue.
> I am referring to this commit specifically
> https://github.com/yadudoc/cloud-tutorials/commit/d75ce87eb94fd8460b9b425c72445265e6074974
> which was made a day ago.
> I am not sure what is the cause of this problem,
> Could you investigate and help me resolve the issue?
> Thanks a lot,
> Regards,
> Raghav
Yadu Nand B
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20141017/e0ea3dac/attachment.html>
More information about the Swift-user
