[Swift-user] Concurrent mappers
Jonathan Ozik
jozik at uchicago.edu
Thu May 29 11:05:16 CDT 2014
Mike,
I'm getting:
Error: Unknown property file.gc.enabled
when I add that to my swift.properties file.
This is using trunk.
Jonathan
On May 29, 2014, at 10:42 AM, Michael Wilde <wilde at anl.gov> wrote:
> Jonathan, the files created by the concurrent mapper default to being
> temporary.
> To make them persist after the swift command terminates, add this to
> swift.properties:
> file.gc.enabled=false
> (This needs to be added to the User Guide. Its desrcibed at the moment
> only in etc/swift.properties):
> # Files mapped by the concurrent mapper (i.e. when you don't
> # explicitly specify a mapper) are deleted when they are not
> # in use any more. This property can be used to prevent
> # files mapped by the concurrent mapper from being deleted.
> # Format:
> # file.gc.enabled=(true|false)
> # Default: true
> - Mike
> On 5/29/14, 10:24 AM, Jonathan Ozik wrote:
>> I'm trying to use concurrent mappers to let swift automatically avoid file name conflicts. After the run is complete, it looks like those files are not retained, or at least do not appear in the location that I've specified. I see a _concurrent directory but it is empty. If I specify a directory as part of the prefix (e.g., <concurrent_mapper;prefix="out/sim",suffix=".out">;) I see an "out" directory inside the _concurrent directory but that directory is empty.
>> Are these files meant to only be temporary?
>> Jonathan
>> Swift-user mailing list
>> Swift-user at ci.uchicago.edu
>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
> Michael Wilde
> Mathematics and Computer Science Computation Institute
> Argonne National Laboratory The University of Chicago
More information about the Swift-user
