[Swift-user] Data transfer error
Bronevetsky, Greg
bronevetsky1 at llnl.gov
Fri May 23 15:33:33 CDT 2014
Yes, at least as long as it is cleaned out at the end of each job so that I don't get memory leaks across jobs.
Greg Bronevetsky
Lawrence Livermore National Lab
(925) 424-5756
bronevetsky at llnl.gov
http://greg.bronevetsky.com
-----Original Message-----
From: Mihael Hategan [mailto:hategan at mcs.anl.gov]
Sent: Friday, May 23, 2014 1:33 PM
To: Bronevetsky, Greg
Cc: swift-user at ci.uchicago.edu
Subject: Re: [Swift-user] Data transfer error
Would it have enough scratch space to run your apps?
Mihael
On Fri, 2014-05-23 at 20:27 +0000, Bronevetsky, Greg wrote:
> Ramdisk mounted at /tmp.
> Greg Bronevetsky
> (925) 424-5756
> Sent: Friday, May 23, 2014 1:26 PM
> On Fri, 2014-05-23 at 19:52 +0000, Bronevetsky, Greg wrote:
> > Looking deeper through the logs I'm noticing the following messages in my -info files:
> > "Job directory mode is: link on shared filesystem"
> > Googling around I noticed that another mode is "local copy". Would running in this mode alleviate pressure on the global scratch file system? If so, how do I use it? Thanks!
> Before I answer that question...
> Do the compute nodes have local storage?
> Mihael
More information about the Swift-user
