[Swift-user] Resuming jobs when script has changed
Bronevetsky, Greg
bronevetsky1 at llnl.gov
Tue May 20 01:18:39 CDT 2014
I'm not sure I'm following. In my case mydir/ and olddir/ are the same. I'm trying to run the script in its original directory within my home directory, while making sure not to re-create files that already exist. The issue that I had is that in my original solution I copied files from my home directory to Swift's intermediate directory and then back, overwriting the original file in my home directory with an identical copy. The first copy (home -> Swift intermediate dir) seems unavoidable but the second seems unnecessary.
Greg Bronevetsky
Lawrence Livermore National Lab
(925) 424-5756
bronevetsky at llnl.gov
http://greg.bronevetsky.com
-----Original Message-----
From: Mihael Hategan [mailto:hategan at mcs.anl.gov]
Sent: Monday, May 19, 2014 11:03 PM
To: Bronevetsky, Greg
Cc: swift-user at ci.uchicago.edu
Subject: Re: [Swift-user] Resuming jobs when script has changed
Sorry. I thought you didn't want the overhead of a copy.
If you do want them in your directory, then map "copy" explicitly to the relevant name.
In other words:
file a <"mydir/a">;
file olda <"olddir/a">;
a = olda;
will copy olddir/a to mydir/a
but
file a;
a = olda;
will not.
Mihael
On Tue, 2014-05-20 at 05:30 +0000, Bronevetsky, Greg wrote:
> Thanks Mihael. I just tried using your operations in my test code (below). It seems to detect whether the files do/don't exist and seems to try to generate the files but they never appear in my directory. During a fresh run in an empty directory I get the following output:
> Swift 0.94.1 swift-r7114 cog-r3803
> RunID: 20140519-2230-4lyyh8me
> Progress: time: Mon, 19 May 2014 22:30:03 -0700
> Progress: time: Mon, 19 May 2014 22:30:04 -0700 Stage in:1
> Submitting:1
> Progress: time: Mon, 19 May 2014 22:30:09 -0700 Active:1 Checking
> status:1
> path=g/g15/bronevet/apps/swift-0.94.1/examples/test/work/dataF,
> exists=false Generating
> file://localhost/_concurrent/data-5fbfabc7-8f5d-4240-82b1-4c7ecfdc33aa
> -path=g/g15/bronevet/apps/swift-0.94.1/examples/test/work/copyF,
> file://localhost/_concurrent/copy-44d394f6-53f3-4f5b-9ec9-fa2c19f5fcdf
> - from
> -Final status: Mon, 19 May 2014 22:30:09 -0700 Finished
> successfully:3
> Greg Bronevetsky
> (925) 424-5756
> import "common";
> type file;
> string
> WORK_PATH="/g/g15/bronevet/apps/swift-0.94.1/examples/test/work";
> app (file outF) writeFile(string message) {
> echo message stdout=@filename(outF); }
> app (file outF) copyFile(file inF) {
> cp @filename(inF) @filename(outF);
> file data;
> file dataOld <single_file_mapper; file="dataF">;
> if(!exists(@strcat(WORK_PATH, "/dataF"))) {
> tracef("Generating %M\n", data);
> (data) = writeData("hello");
> } else
> { data = dataOld; }
> file copy;
> file copyOld <single_file_mapper; file="copyF">;
> if(!exists(@strcat(WORK_PATH, "/copyF"))) {
> tracef("Generating %M from %M\n", copy, data);
> (copy) = copyFile(data);
> } else
> { copy = copyOld; }
> Sent: Monday, May 19, 2014 4:25 PM
> Here's the swift part. It will only work with absolute paths. It can probably be modified to only work with relative paths.
> type file;
> app (file outf) existsApp(string path) {
> existsApp path stdout=@filename(outf); }
> (boolean result) exists(string path) {
> result = readData(existsApp(path));
> file there <"/bin/bash">;
> file notthere <"/bin/notthere">;
> tracef("Y %b\n", exists(@filename(there))); tracef("N %b\n",
> exists(@filename(notthere)));
> And existsApp:
> #!/bin/bash
> # add leading / since @filename removes it # this will not work with swift > 0.94 if [ -f "/$1" ]; then
> echo "true"
> else
> echo "false"
> fi
> On Mon, 2014-05-19 at 15:28 -0700, Mihael Hategan wrote:
> > On Mon, 2014-05-19 at 22:21 +0000, Bronevetsky, Greg wrote:
> > > Thanks, Mihael! I've modified my original code based on your suggestions (new code below) but I'm getting the following error:
> > > Could not start execution
> > > Procedure exists is not defined.
> > Sorry. That's where your implementation of exists for absolute path
> > names goes. I'll send you the relevant code shortly. I'm working on
> > the array splitting issue now.
> > Mihael
> > _______________________________________________
> > Swift-user mailing list
> > Swift-user at ci.uchicago.edu
> > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
More information about the Swift-user
