[Swift-user] Treatment of booleans in Swift
Bronevetsky, Greg bronevetsky1 at llnl.gov
Mon May 19 18:31:11 CDT 2014
> -          tracef doesn't have a format option for Booleans, forcing
> me to convert them to strings. Running @toInt on a Boolean produces:
> "java.lang.NumberFormatException: For input string: "false"".
I think the documentation is lying (by omission) about that. Try "%b".
Thanks!
All of "True" and "true" and "TRUE" and "tRuE" (and all other case
combinations) should work. The implementation uses Java's Boolean.valueOf(String), which calls this:
    private static boolean toBoolean(String name) {
        return ((name != null) && name.equalsIgnoreCase("true"));
Great! I must have had another bug that I thought was caused by mis-parsing of file contents.
Greg Bronevetsky
Lawrence Livermore National Lab
(925) 424-5756
bronevetsky at llnl.gov
http://greg.bronevetsky.com
-----Original Message-----
From: Mihael Hategan [mailto:hategan at mcs.anl.gov]
Sent: Monday, May 19, 2014 4:29 PM
To: Bronevetsky, Greg
Cc: swift-user at ci.uchicago.edu
Subject: Re: [Swift-user] Treatment of booleans in Swift
On Mon, 2014-05-19 at 23:22 +0000, Bronevetsky, Greg wrote:
> I've been working with Booleans recently and I've run into a couple of issues with them that might be a problem for others:
> -          It is not clear how to format files to be read by
> readData() if the data in question is a Boolean. Based on
> experimentation I discovered that the correct strings are
> "True"/"False" rather than "true"/"false" or "0"/"1". It would be
> useful to document this in the description of readData().
Mihael
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140519/b0d21cf9/attachment.html>
More information about the Swift-user mailing list
