[Swift-user] Reduction trees
Mihael Hategan
hategan at mcs.anl.gov
Mon May 19 18:12:23 CDT 2014
On Mon, 2014-05-19 at 14:54 -0700, Mihael Hategan wrote:
> Well, ... I can probably write a hackish split function that you can use
> with 0.94. Give me a few hours.
Ok, here's the basic idea:
(file[][] result) split(file[] array, int n) {
// need to explicitly keep track of keys since
// writeData does not write the array keys
int[auto] keys;
foreach v, k in array {
keys << k;
file kf = writeData(keys);
file kfs = splitArrayApp(kf, n); // make pointers to original keys
int[][] skeys = readStructured(kfs);
foreach slice, sliceIndex in skeys {
foreach index in slice {
result[sliceIndex][index] = array[index];
Attached are full versions of scripts. You will need to add
splitArrayApp to tc.data. Please try to run it and let me know if it
works. My development 0.94 might be slightly different from what you
have.
Mihael
type file;
// ----- Start of split related stuff
app (file outf) splitArrayApp(file inf, int n) {
splitArrayApp @filename(inf) n stdout=@filename(outf);
int[auto] keys;
keys << k;
// ----- End of split related stuff
file[] array;
app (file outf) gen(int i) {
echo i stdout=@filename(outf);
foreach i in [1:13] {
file f <single_file_mapper; file=@strcat("f", i * 2)>;
f = gen(i * 3);
array[i * 2] = f;
file[][] split = split(array, 5);
foreach v1, k1 in split {
foreach v2, k2 in v1 {
tracef("array[%i][%i] -> %s\n", k1, k2, @filename(v2));
Type: text/x-python
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140519/479ddf3d/attachment.py>
More information about the Swift-user
