[Swift-user] Reduction trees
Mihael Hategan
hategan at mcs.anl.gov
Mon May 19 16:31:10 CDT 2014
You are correct. There does not seem to be an easy way to slice a sparse
array (or an array with non-int keys).
I've filed an enhancement report to add the relevant feature
(https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=1275)
In the mean time, I'm trying to see if there might be a hack that can
allow you to do what you need. Can you post the code that generates the
sparse arrays you mention? I'm trying to picture a solution, but it's
hard without a concrete example.
Mihael
On Mon, 2014-05-19 at 14:09 +0000, Bronevetsky, Greg wrote:
> What I mean is that I have an array of files computed by my individual
> tasks. To do a reduction tree on them I need to create a sub-array of
> the first 100, the second 100, etc. so that each sub-array can be
> merged independently. In my code example below I skip this step and
> simply generate a region of numbers (minR, maxR) for each node in my
> reduction tree and then do stuff with the numbers. Now I need for
> these numbers to correspond to indexes in an array of files.
> Greg Bronevetsky
> Lawrence Livermore National Lab
> (925) 424-5756
> bronevetsky at llnl.gov
> http://greg.bronevetsky.com
> -----Original Message-----
> From: Mihael Hategan [mailto:hategan at mcs.anl.gov]
> Sent: Sunday, May 18, 2014 5:05 PM
> To: Bronevetsky, Greg
> Cc: swift-user at ci.uchicago.edu
> Subject: Re: [Swift-user] Reduction trees
> Hi,
> Can you be more specific about what you mean by "subsets of keys" below?
> Specifically, how are these sub sets defined?
> Mihael
> On Sun, 2014-05-18 at 22:16 +0000, Bronevetsky, Greg wrote:
> > I need to implement a reduction three in Swift to aggregate the
> > results of many individual runs. I've written the simple algorithm
> > below, which works when all my runs correspond to numbers in a fixed
> > range. However, in reality I have a regular or associative array of
> > files produced by individual runs. How do I adapt the code below to
> > this scenario? I don't see any way to iterate over subsets of array
> > indexes/keys. Thanks!
> > Greg Bronevetsky
> > (925) 424-5756
> > bronevetsky at llnl.gov<mailto:bronevetsky at llnl.gov>
> > type file;
> > app (file outFile) gen(string arg)
> > echo arg stdout=@filename(outFile);
> > app (file summaryFile) catBase(file inFiles[]) {
> > cat @filenames(inFiles) stdout=@filename(summaryFile); }
> > // Concatenate the text of numbers in range [minR - maxR) (includes
> > minR, not maxR) (file summaryFile) catTree(int minR, int maxR, int radix, int level) {
> > file subFiles[];
> > if((maxR-minR) <= radix) {
> > //tracef("catTree: leaf: minR=%i, minR=%i\n", minR, maxR);
> > foreach b in [0: (maxR-minR)-1] {
> > //tracef("catTree: leaf: b=%i\n", b);
> > file curLeafFile <single_file_mapper; file=@strcat("file.", at toString(minR+b))>;
> > (curLeafFile) = gen(@toString(minR+b));
> > subFiles[b] = curLeafFile;
> > } else {
> > int size=maxR-minR;
> > //tracef("catTree: node: minR=%i, minR=%i\n", minR, maxR);
> > foreach b in [0: radix-1] {
> > file curNodeFile <single_file_mapper; file=@strcat("node.level_", at toString(level),".startVal_", at toString(minR+b))>;
> > int start = minR + (size*b)%/radix;
> > int end = minR + (size*(b+1))%/radix;
> > //tracef("catTree: node: b=%i [%i - %i]\n", b, start, end);
> > (curNodeFile) = catTree(start, end, radix, level+1);
> > subFiles[b] = curNodeFile;
> > //tracef("catBase: inFiles=%q\n", @filenames(subFiles));
> > (summaryFile) = catBase(subFiles);
> > file allFile <single_file_mapper; file="all">;
> > (allFile) = catTree(0, 31, 2, 0);
> > _______________________________________________
> > Swift-user mailing list
> > Swift-user at ci.uchicago.edu
> > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
More information about the Swift-user
