[Swift-user] Resuming jobs when script has changed
Bronevetsky, Greg
bronevetsky1 at llnl.gov
Mon May 19 12:39:18 CDT 2014
Based on your suggestion, I came up with the following code. However, I'm having an issue with it. If I use an external mapper I can choose whether to return a file or not based on whether it already exists. However, once I made a decision not to return a file from the external mapper because it has already been generated, I don't see how to enable subsequent workflow steps to take it as input. In the code below, if dataFile exists but copyFile does not, I get the following error:
Execution failed:
org.griphyn.vdl.mapping.InvalidPathException: Array index '0' not found for f1 of size 0
copyFile, testResume.swift, line 20
Greg Bronevetsky
Lawrence Livermore National Lab
(925) 424-5756
bronevetsky at llnl.gov<mailto:bronevetsky at llnl.gov>
http://greg.bronevetsky.com
Swift:
type file;
string ROOT_PATH="/g/g15/bronevet/apps/swift-0.94.1/examples/test";
app (file outF) writeFile(string message) {
echo message stdout=@filename(outF);
app (file outF) copyFile(file inF) {
cp @filename(inF) @filename(outF);
file f1[] <ext;exec=@strcat(ROOT_PATH,"/immutable.py"), fName="dataFile">;
if(@length(f1) == 1) {
f1[0] = writeFile("hello");
file f2[] <ext;exec=@strcat(ROOT_PATH,"/immutable.py"), fName="copyFile">;
if(@length(f2) == 1) {
f2[0] = copyFile(f1[0]);
External mapper in Python:
#!/usr/apps/python2.7.3/bin/python
import argparse
import sys
import os
def main(argv):
parser = argparse.ArgumentParser(description='Merge stats and distances files from experiments.')
parser.add_argument('-fName', dest='fName', action='store', nargs="+", help='List of files to check for existence')
args = parser.parse_args()
for i in range(0, len(args.fName)):
if(not (os.path.exists(args.fName[i]))):
print "["+str(i)+"] "+args.fName[i]
if __name__ == "__main__":
main(sys.argv[1:])
From: swift-user-bounces at ci.uchicago.edu [mailto:swift-user-bounces at ci.uchicago.edu] On Behalf Of Michael Wilde
Sent: Friday, May 16, 2014 10:53 AM
To: swift-user at ci.uchicago.edu
Subject: Re: [Swift-user] Resuming jobs when script has changed
Hi Greg,
The Swift resume mechanism can't do this, as its driven by internal variables name within a Swift run, not by external file existence.
The best way to do what you describe below is to write an external input file mapper (e.g. a simple shell or py script) that returns only the files that still need to be produced or processed. (This is the "ext" mapper: http://swift-lang.org/guides/release-0.94/userguide/userguide.html#_external_mapper )
You can also call a local app to determine what files need to be produced, then use readData() to read those file names into an array, and array_mapper to map an array of remaining work to do.
Would one of these approaches meet your needs?
- Mike
On 5/16/14, 12:35 PM, Bronevetsky, Greg wrote:
I have Swift scripts that scan some portion of a design space and after I have scanned a sub-space of all the possibilities I modify the script to target a different, overlapping portion of the design space. However, it seems that when I do this Swift ignores the fact that I've already computed many of the tasks in the new run when I performed the prior run, and re-executes them redundantly. Is there a way for me to avoid such redundant executions? Can the -resume flag be used in this case?
Greg Bronevetsky
(925) 424-5756
bronevetsky at llnl.gov<mailto:bronevetsky at llnl.gov><mailto:bronevetsky at llnl.gov><mailto:bronevetsky at llnl.gov>
Swift-user mailing list
Swift-user at ci.uchicago.edu<mailto:Swift-user at ci.uchicago.edu>
https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
Michael Wilde
Mathematics and Computer Science Computation Institute
Argonne National Laboratory The University of Chicago
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140519/a0fbdad5/attachment.html>
More information about the Swift-user
