[Swift-user] Swift crash
William Catino wcatino at gmail.com
Tue May 6 17:53:52 CDT 2014
I have a script that crashed 3 times, then succeeded, with no change.
When it crashed, the .err file in the data directory contained a message
about not finding a file whose name included
           /usr/lib64/libpython2.6.so.1.0
The attached log file that corresponds to a crash is:
               df-20140506-1724-d6au5ct7.log
The attached log file that corresponds to a subsequent success is:
               df-20140506-1727-39v1is9b.log
I might have specific files confused, but these files (and others from
prior crashes) are located in my home directory on OSG, at /home/wcatino/df.
This configuration is identical to that used when working with Mike today,
except that the data directory was reduced to 5 files.
I also noticed that my PATH is pointing swift to version 0.94 rather than
0.95.
Perhaps I should change my PATH to fix this.
The instructions I followed had me append the 0.95 path to PATH, which
contains a 0.94 path earlier in the PATH string.
Thanks.
William Catino, Ph.D.
Principal Software Engineer
Knowledge Lab | Computation Institute | University of Chicago
773.603.9481
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140506/ae2dd215/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140506/ae2dd215/attachment.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140506/ae2dd215/attachment-0001.obj>
More information about the Swift-user mailing list
