[Swift-user] structured_regexp_mapper does not work
Michael Wilde wilde at anl.gov
Sun May 4 18:35:57 CDT 2014
On 5/4/14, 4:45 PM, Kamil Slowikowski wrote:
> I cannot reproduce the example in the user guide:
> http://swift-lang.org/guides/release-0.94/userguide/userguide.html#_structured_regular_expression_mapper
> Please see the script and console output below.
Kamil, thanks for reporting this.
Im not yet certain, but I think the example should be recoded to make
the source (in addition to the dest) array be an array of type file
rather than of type string, and also to trace @filenames( ) of the dest
file array rather than the whole array:
$ cat test2.swift
type file;
string s[] = ["picture.gif", "hello.gif", "world.gif"];
file g[]<array_mapper; files=s>;
file f[] <structured_regexp_mapper;
             source=g,
             match="(.*)gif",
             transform="\\1jpg">;
trace(@filenames(f));
$ swift test2.swift
Swift 0.94.1 swift-r7114 cog-r3803
RunID: 20140504-2309-rfdo9614
Progress:  time: Sun, 04 May 2014 23:09:21 +0000
SwiftScript trace: {0 = picture.jpg, 1 = hello.jpg, 2 = world.jpg}
Final status: Sun, 04 May 2014 23:09:21 +0000
I filed a bug ticket (#1271) to fix the exception, determine the
(currently) desired behavior, and update the User Guide:
   https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=1271
> 1. Is Swift currently being developed?
Yes, actively.
> 2. Are there plans to improve the documentation soon?
Yes - this need is well-recognized. The User Guide improves but rather
slowly. I can't provide a date when this will start accelerating.
> 3. Is it possible to move the documentation to a platform where your users
> can contribute?
Yes, that's a good idea. We are planning a move to GitHub. We were a bit
more focused on enabling users to contribute to code, but enabling user
documentation contributions more readily is a great idea. Our docs are
currently written in AsciiDoc; we'll look for ways to do this, but for
now, just mail improvement text to swift-user.  (Ideally, please join
the swift-user list so that your posts are not blocked for moderation).
> 4. Is the project well-funded and staffed?
We're very grateful for the funding we have, but its barely enough to
support our user base.  About 7 people work on Swift, under relatively
modest funding. Less than 1.5 FTE is available to support of the Swift
0.9 -> 1.0 product trajectory; the rest of the team is funded to do CS
research or support specific science application user groups.  We're
actively pursuing expanded funding and other means of sustaining Swift,
including working more aggressively to grow a sustaining open source
community.
- Mike
> Thanks,
> Kamil
> Here is the script: (copied from the guide verbatim)
> $ cat test.swift
> type file;
>              source=s,
>              match="(.*)gif",
> trace(f);
> Here is the output:
> $ swift test.swift
> RunID: 20140504-1718-q5qk8b9a
> Progress:  time: Sun, 04 May 2014 17:18:24 -0400
> Execution failed:
>          f, line 3 had mapping errors
> Caused by:
>          java.lang.NullPointerException
>          at
> org.griphyn.vdl.mapping.file.StructuredRegularExpressionMapper.map(StructuredRegularExpressionMapper.java:106)
>          at
> org.griphyn.vdl.mapping.RootDataNode.addExisting(RootDataNode.java:173)
>          at
> org.griphyn.vdl.mapping.RootDataNode.checkInputs(RootDataNode.java:128)
>          at
> org.griphyn.vdl.mapping.RootArrayDataNode.checkInputs(RootArrayDataNode.java:104)
>          at
> org.griphyn.vdl.mapping.RootArrayDataNode.innerInit(RootArrayDataNode.java:92)
>          at
> org.griphyn.vdl.mapping.RootArrayDataNode.futureModified(RootArrayDataNode.java:113)
>          at
> org.griphyn.vdl.karajan.ArrayIndexFutureList$1.run(ArrayIndexFutureList.java:156)
>          at
> java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:441)
>          at
> java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
>          at java.util.concurrent.FutureTask.run(FutureTask.java:138)
>          at
> java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
>          at
> java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
>          at java.lang.Thread.run(Thread.java:662)
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
Michael Wilde
Mathematics and Computer Science          Computation Institute
Argonne National Laboratory               The University of Chicago
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140504/7b8e99e4/attachment.html>
More information about the Swift-user mailing list
