[Swift-user] [Swift-devel] Multiple output files
Michael Wilde
wilde at anl.gov
Thu Mar 27 22:00:35 CDT 2014
Jonathan, I'd need to test this, but my suspicion is that specifying
location only changes the directory that the mapper should look in.
But you also need to give it a prefix and/or a suffix - else it won't
know what you want it to map *within* that drectory.
My guess is that you had a mapper with "prefix=" that worked, and you
just changed "prefix" to "location"?
Also - please see Mihael's post to swift-devel in the past hour. He has
committed the enhancement to dynamically map an output array of files on
the compute node, as you requested and we discussed. I think you'll
have to build a swift from trunk source to try this, but thats only an
svn co and a few commands (see Download at swift-lang.org).
Mike
On 3/27/14, 5:02 PM, Jonathan Ozik wrote:
> Mike,
> I've been making a good amount of progress and I'm able to
> successfully run a number of concurrent instances locally.
> I had a question about the filesys_mapper, and how it might (or might
> not) be able to handle nested folders. If I point it to a "location"
> like this:
> file data[] <filesys_mapper;location="data">;
> I get a file not found error when it is used as an input (presumably
> because that is when the mapper gets resolved) if there is a nested
> folder within that location.
> data/
> temp.txt
> insideData/
> temp1.txt
> Is this expected behavior? If so, is there a workaround to gather all
> files under a folder as input?
> Jonathan
> On Mar 22, 2014, at 11:31 AM, Michael Wilde <wilde at anl.gov
> <mailto:wilde at anl.gov>> wrote:
>> This is now filed as enhancement bug 1225 and assigned to you,
>> Mihael. The description has been revised as you suggested, to
>> propose that the feature be first done using simple_mapper rather
>> than a new mapper.
>> - Mike
>> On 3/21/14, 8:39 AM, Michael Wilde wrote:
>>> Mihael, All,
>>> I'd like to propose a Swift/K feature to provide a reasonable
>>> solution to this very common need for an app to return a dynamically
>>> determined set of files.
>>> file dynarry[ ] <runtime; prefix="myoutput.", suffix=".out",
>>> indexes="int">;
>>> dynarry = myApp(myArgs);
>>> The "runtime" mapper should initially have the same arguments and
>>> semantics (roughly) as simple_mapper, except for two new arguments:
>>> "indexes" which determines how the matched file names will be
>>> indexed in the returned array
>>> "int" | "string" | "sequential"
>>> sequential: return the matched files as consecutive integer indices
>>> starting with 0
>>> int: expect the filename component between prefix and suffix to be
>>> convertible to an integer, and use that as the index
>>> eg myfile.012.out and myfile.204.out will return an array with the
>>> mapped files at indices 12 and 204.
>>> string: similar to int but return a string-indexed associative array.
>>> "sequential" is simplest and should be the default.
>>> "paths" which determines if the match names will be absolute or
>>> relative to the job dir
>>> paths="relative" | "absolute"
>>> (may not be needed if this can be determined uniquely based on the
>>> location argument.
>>> swiftwrap will allow array variables mapped in this manner to have
>>> any number of files, including zero. I.e. "runtime-mapped" files
>>> should not be listed in the expected output list for an app
>>> invocation. Its up to the users app to ensure that some files match
>>> the pattern. An additional arg could set e.g. minfiles and/or
>>> maxfiles, in which case the wrapper code needs to validate the count
>>> of files matched and returned, but not their exact names.
>>> We can call this mapper "experimental" until we validate its
>>> usability and suitability as a permanent feature. But as we hope to
>>> revise the entire mapper family and semantics, in a sense all
>>> mappers are subject to change.
>>> Mihael, is the definition sound, and how long would it take you to
>>> develop it?
>>> Thanks,
>>> - Mike
>> Michael Wilde
>> Mathematics and Computer Science Computation Institute
>> Argonne National Laboratory The University of Chicago
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140327/d55a7b35/attachment.html>
More information about the Swift-user
