[Swift-user] Persistent Coasters & 0.95 RC6
Yadu Nand yadudoc1729 at gmail.com
Wed Jun 18 12:30:43 CDT 2014
Hi Matthew,
Could you mail us a tar ball of your runNNN directory ?
Yadu
On Wed, Jun 18, 2014 at 12:20 PM, Matthew Shaxted <Matthew.Shaxted at som.com>
wrote:
> Hi, I am trying to upgrade my 0.94 persistent-coasters scripts to 0.95,
> and seem to be experiencing some difficulty when trying to execute coaster
> jobs. I can run these test scripts locally with no problems.
> I have a swift.properties file that is outlined below. I can successfully
> start-coaster-service using a hosts.txt file. I notice that this process
> creates a unique sites.xml file but my swift.properties file should match
> it. I am manually defining the coaster service port to match that in the
> swift.properties file.
> When I try to run the below test.swift script, I am getting the error that
> looks like below.
> Any idea what may be causing this issue?
> *Swift.Properties File*
> sitedir.keep=true
> wrapperlog.always.transfer=true
> site.local {
>    tasksPerWorker=8
>    taskWalltime=00:15:00
>    maxJobs=1
>    workdir=/home/som/EnergyPlus/test/work
>    filesystem=local
> app.local.echoLocal=/bin/echo
> site.persistent-coasters {
>    jobManager=coaster-persistent:local:local:http://localhost:50200
>    tasksPerWorker=8
>    maxJobs=1
>    filesystem=local
> app.persistent-coasters.echoCoast=/bin/echo
> site=local,persistent-coasters
> *test.swift file*
> app echo (string s) {
>    echoCoast s;
> echo("HELLO WORLD");
> *test.swift Error*
> *from the run.log file*
> swift NO_STATUS_FILE jobid=echoCoast-5135s9sl - Error file missing
> 2014-06-18 12:13:25,214-0500 DEBUG swift APPLICATION_EXCEPTION
> jobid=echoCoast-5135s9sl - Application exception: Job failed with and exit
> code of 127
> *Command line output*
> Swift 0.95 RC6 swift-r7900 cog-r3908
> RunID: run003
> Progress: Wed, 18 Jun 2014 12:13:24-0500
> Execution failed:
> Exception in echoCoast:
>     Arguments: [HELLO WORLD]
>     Host: persistent-coasters
>     Directory: test-run003/jobs/5/echoCoast-5135s9sl
>         exception @ swift-int.k, line: 530
> Caused by: Job failed with and exit code of 127
> org.globus.cog.abstraction.impl.common.execution.JobException: Job failed
> with and exit code of 127 (exit code: 127)
>         at
> org.globus.cog.abstraction.coaster.service.local.JobStatusHandler.requestComplete(JobStatusHandler.java:40)
>         at
> org.globus.cog.coaster.handlers.RequestHandler.receiveCompleted(RequestHandler.java:88)
>         at
> org.globus.cog.coaster.channels.AbstractCoasterChannel.handleRequest(AbstractCoasterChannel.java:527)
>         at
> org.globus.cog.coaster.channels.AbstractStreamCoasterChannel.stepNIO(AbstractStreamCoasterChannel.java:238)
>         at
> org.globus.cog.coaster.channels.NIOMultiplexer.loop(NIOMultiplexer.java:97)
>         at
> org.globus.cog.coaster.channels.NIOMultiplexer.run(NIOMultiplexer.java:56)
> Caused by: org.globus.cog.abstraction.impl.common.execution.JobException:
>         at
>         at
>         at
>         at
>         at
>         at
> (exit code: 127)
> MATTHEW SHAXTED
> SKIDMORE, OWINGS & MERRILL LLP
> 224 South Michigan Ave.
> Chicago, IL 60604
> TEL: 312.360.4368
> FAX: 312.360.4545
> matthew.shaxted at som.com
> [image: cid:image9d6458.png at 2965c709.c87949ac]
> WWW.SOM.COM <http://www.som.com/>
> The information contained in this communication may be confidential, is
> intended only for the use of the recipient(s) named above, and may be
> legally privileged. If the reader of this message is not the intended
> recipient, you are hereby notified that any dissemination, distribution, or
> copying of this communication, or any of its contents, is strictly
> prohibited and may be unlawful. If you have received this communication in
> error, please return it to the sender immediately and delete the original
> message and any copy of it from your computer system. If you have any
> questions concerning this message, please contact the sender.
> [image: cid:image93798a.gif at f078f826.ddd94773]
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
Yadu Nand B
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140618/ef0440b3/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140618/ef0440b3/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140618/ef0440b3/attachment-0001.png>
More information about the Swift-user mailing list
