[Swift-user] Sites.xml to swift.properties Conversion
    David Kelly
    davidkelly at uchicago.edu
    Tue Jun 17 16:59:48 CDT 2014
Could you paste the new swift.properties please? The jobmanager line I gave
should translate to:
<execution provider="coaster-persistent" jobmanager="local:local" url="
http://localhost:56069"/>
On Tue, Jun 17, 2014 at 4:56 PM, Matthew Shaxted <Matthew.Shaxted at som.com>
wrote:
> Yes I did just fix this and it is generating two  pools (below), but I
> still cannot identify the execution provider for some odd reason.
> <?xml version="1.0" encoding="UTF-8"?>
> <config xmlns="http://www.ci.uchicago.edu/swift/SwiftSites">
> <pool handle="local">
> <filesystem provider="local"/>
> <profile namespace="globus" key="slots">1</profile>
> <profile namespace="karajan" key="jobThrottle">0.03</profile>
> <workdirectory>/home/som/EnergyPlus/test/work</workdirectory>
> <execution provider="coaster" jobmanager="local:local"/>
> <profile namespace="globus" key="jobsPerNode">8</profile>
> <profile namespace="globus" key="maxwalltime">00:15:00</profile>
> </pool>
> <pool handle="coaster">
> </pool>
> </config>
> MATTHEW SHAXTED
> SKIDMORE, OWINGS & MERRILL LLP
> 224 South Michigan Ave.
> Chicago, IL 60604
> TEL: 312.360.4368
> FAX: 312.360.4545
> matthew.shaxted at som.com
> [image: cid:image9d6458.png at 2965c709.c87949ac]
> WWW.SOM.COM <http://www.som.com/>
> The information contained in this communication may be confidential, is
> intended only for the use of the recipient(s) named above, and may be
> legally privileged. If the reader of this message is not the intended
> recipient, you are hereby notified that any dissemination, distribution, or
> copying of this communication, or any of its contents, is strictly
> prohibited and may be unlawful. If you have received this communication in
> error, please return it to the sender immediately and delete the original
> message and any copy of it from your computer system. If you have any
> questions concerning this message, please contact the sender.
> [image: cid:image93798a.gif at f078f826.ddd94773]
> *From:* Yadu Nand [mailto:yadudoc1729 at gmail.com]
> *Sent:* Tuesday, June 17, 2014 4:49 PM
> *To:* David Kelly
> *Cc:* Matthew Shaxted; swift-user at ci.uchicago.edu
> *Subject:* Re: [Swift-user] Sites.xml to swift.properties Conversion
> Hi David,
> Isn't the swift.properties supposed to say : site=local,persistent-coaster
> instead of the site variable being redefined in what looks like a single
> swift.properties file ?
> -Yadu
> On Tue, Jun 17, 2014 at 4:46 PM, David Kelly <davidkelly at uchicago.edu>
> wrote:
> Hi Matthew,
> The new config assumes the provider is just 'coaster' by default, but it's
> possible to override this and specify your own url (just a little more
> verbose). This property should do it:
> jobManager=coaster-persistent:local:local:http://localhost:56069
> I'll make a note to add documentation about non-'coaster' setups in the
> userguide.
> David
> On Tue, Jun 17, 2014 at 4:03 PM, Matthew Shaxted <Matthew.Shaxted at som.com>
> wrote:
> Hi Swift support,
> I am in the process of converting my 0.94 swift scripts to 0.95, and I am
> having a bit of difficulties creating the correct sites properties from the
> new swift.properties file.
> I am trying to convert the sites.xml file below, and when I attempt to
> identify site.persistent-coaster{provider=”coaster-persistent”…} in the
> swift.properties file I am getting an “Error: Unknown property
> site.persistent-coasters.provider”.
> Can anyone please lend some insight on how to best convert from a
> sites.xml to a swift.properties file? I am using Swift 0.95 RC6 swift-r7900
> cog-r3908
> Thanks,
> Matthew
> *0.94 Sites.xml File*
> <config>
>    <pool handle="localhost">
>       <profile namespace="karajan" key="jobThrottle">0</profile>
>       <profile namespace="karajan" key="initialScore">10000</profile>
>       <workdirectory>{env.HOME}/work</workdirectory>
>    </pool>
>   <pool handle="persistent-coasters">
>                url="http://localhost:56069"
>     <profile namespace="globus" key="workerManager">passive</profile>
>     <profile namespace="globus" key="jobsPerNode">2</profile>
>     <profile key="jobThrottle" namespace="karajan">.01999</profile>
>     <filesystem provider="local" url="none" />
>     <workdirectory>/tmp/shaxted</workdirectory>
>   </pool>
> </config>
> *My new swift.properties file look like below:*
> sitedir.keep=true
> wrapperlog.always.transfer=true
> site.local {
>    tasksPerWorker=8
>    taskWalltime=00:15:00
>    maxJobs=1
>    workdir=/home/som/EnergyPlus/test/work
>    filesystem=local
> app.local.echo=/bin/echo
> site=local
> site. persistent-coaster {
>    provider=coaster
>    tasksPerWorker=8
>    maxJobs=2
>    filesystem=local
> app.persistent-coaster.echo=/bin/echo
> site=persistent-coaster
> MATTHEW SHAXTED
> Chicago, IL 60604
> TEL: 312.360.4368
> FAX: 312.360.4545
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
> Yadu Nand B
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140617/f5d4f357/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140617/f5d4f357/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140617/f5d4f357/attachment-0001.png>
More information about the Swift-user
