[Swift-user] Java version to build and run Swift
Guilherme Gall gmgall at lncc.br
Tue Jun 3 16:25:24 CDT 2014
Em 03-06-2014 17:40, Mihael Hategan escreveu:
> On Tue, 2014-06-03 at 12:29 -0700, Mihael Hategan wrote:
>> On Tue, 2014-06-03 at 12:22 -0700, Mihael Hategan wrote:
>>> I'm not sure whether this should or should not generally result
>>> in an error (although it should be caught earlier and reported
>>> nicer if it should). I'll think about it.
>> I think it's a reasonable pattern, so this should not produce an
>>  error.
>> I see that in 0.94 the list of stage ins and outs is stripped of
>> duplicates before being sent to the app and that is missing in
>> trunk. I'll have a fix shortly.
> Done. There is a fix in swift trunk (r7904).
> Mihael
Hello Mihael,
With the newest revision everything worked fine in all machines I have
Swift installed. Even with the alt.asc file being passed to the app twice.
Thank you very much for your help.
Guilherme Gall
CSR/LNCC
GPG Public Key ID: A65ED0D5
More information about the Swift-user mailing list
