[Swift-user] swift submitting message for long time
Mihael Hategan hategan at mcs.anl.gov
Tue Jan 21 16:45:37 CST 2014
Yeah, that's "normal". Submitting means that the provider got the job.
Before the coaster service is started, and if you're using the AutoCA,
some proxy stuff needs to be set up. With SSH-CL this might take a
while, since each invocation of an ssh command does some heavy crypto
stuff. I can try to see if the number of operations can be reduced, but
it's not exactly high on my list.
Mihael
On Tue, 2014-01-21 at 16:40 -0600, Ketan Maheshwari wrote:
> Hi,
> For the ssh-cl:xxx cases, with the trunk, I am getting "submitting" status
> message for a long time but seems nothing is being submitted. In log, I see
> the following messages which seems off:
> Submit: in: null command: ssh -p 22 blues.lcrc.anl.gov ls -1
> /home/ketan/.globus/ssh*-*-*
> Copying proxy
> Submit: in: null command: scp -p -P 22
> /var/folders/6k/9pg8w51j7wj_q1wjw15969400000gn/T/sshproxy-1798790086-1391553457
> blues.lcrc.anl.gov:/home/ketan/.globus/sshproxy-1798790086-1391553457
> Copying certificate
> /var/folders/6k/9pg8w51j7wj_q1wjw15969400000gn/T/sshCAcert-1798790086-1391553457.pem
> blues.lcrc.anl.gov:/home/ketan/.globus/sshCAcert-1798790086-1391553457.pem
> Copying signing policy file
> /var/folders/6k/9pg8w51j7wj_q1wjw15969400000gn/T/sshCAcert-1798790086-1391553457.signing_policy
> blues.lcrc.anl.gov:
> /home/ketan/.globus/sshCAcert-1798790086-1391553457.signing_policy
> This is going from my laptop into blues. The rundir is attached.
> Thanks,
> Ketan
> Hi,
> status message for a long time but seems nothing is being submitted.
> In log, I see the following messages which seems off:
> -1 /home/ketan/.globus/ssh*-*-*
> Copying proxy
> 22 /var/folders/6k/9pg8w51j7wj_q1wjw15969400000gn/T/sshproxy-1798790086-1391553457 blues.lcrc.anl.gov:/home/ketan/.globus/sshproxy-1798790086-1391553457
> Copying certificate
> 22 /var/folders/6k/9pg8w51j7wj_q1wjw15969400000gn/T/sshCAcert-1798790086-1391553457.pem blues.lcrc.anl.gov:/home/ketan/.globus/sshCAcert-1798790086-1391553457.pem
> 22 /var/folders/6k/9pg8w51j7wj_q1wjw15969400000gn/T/sshCAcert-1798790086-1391553457.signing_policy blues.lcrc.anl.gov:/home/ketan/.globus/sshCAcert-1798790086-1391553457.signing_policy
> Thanks,
> Ketan
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
More information about the Swift-user mailing list
