[Swift-user] sites.xml for cloud
David Kelly
davidk at ci.uchicago.edu
Wed Jan 15 10:17:46 CST 2014
Hi Khawar,
For running with the cloud tutorial, all the settings are defined in a file
called scs/coaster-service.conf. The only things you should need to change
there is the list of IP addresses, the remote username, and remote
directories to use.
When you run the command "source setup.sh", it should start the workers on
remote sites and create a sites.xml file in each the part directories. Are
you getting any errors when you run "source setup.sh"?
David
On Wed, Jan 15, 2014 at 9:34 AM, Khawar Ahmad <khawar.ahmad at cern.ch> wrote:
> Hi,
> I am trying to use SWIFT to run sample programs on my test Cloud setup. I
> am following a tutorial (
> http://swift-lang.org/tutorials/cloud/tutorial.html).
> However, the sites.xml file for Part4 is empty and I get the following
> error from swift
> "Execution failed:
> Could not load file sites.xml:
> com.thoughtworks.xstream.io.StreamException: : input contained no data"
> Can you tell me what are the settings to run jobs in the Cloud
> environment? The Cloud is setup using OpenStack.
> Regards,
> Khawar
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140115/d31e6c64/attachment.html>
More information about the Swift-user
