[Swift-user] array append
Bronevetsky, Greg
bronevetsky1 at llnl.gov
Thu Feb 27 18:31:40 CST 2014
I'm trying to use the array append function in Swift 0.94.1, based on Section 2.3 of the user guide (http://swift-lang.org/guides/release-0.94/userguide/userguide.html)
Given the following program:
int[auto] array;
foreach i in [1:100] {
append(array, i * 2);
I run swift on it and get this following error:
> swift test.swift
Could not start execution
Compile error in foreach statement at line 3
Compile error in procedure invocation at line 4
Procedure append is not declared.
How should I be using the append function to avoid this error? Thank you!
Greg Bronevetsky
Lawrence Livermore National Lab
(925) 424-5756
bronevetsky at llnl.gov<mailto:bronevetsky at llnl.gov>
http://greg.bronevetsky.com
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140228/95720cf6/attachment.html>
More information about the Swift-user
