[Swift-user] Coaster Service Startup Time on OSDC
David Kelly davidkelly at uchicago.edu
Mon Feb 17 14:14:29 CST 2014
Hi Matthew,
I set up a test on OSDC with 10 nodes. I did notice something strange
there. When I try to SSH from the Sullivan head node to one of my CentOS
instances, it takes much longer than it should:
dkelly at kg14-compute-1:~$ time ssh root at 172.16.1.236 ls
Warning: Permanently added '172.16.1.236' (RSA) to the list of known hosts.
anaconda-ks.cfg
install.log
install.log.syslog
real 0m25.197s
Are you running start-coaster-service from the Sullivan head node? For each
node in your node list, there are three SSH commands (one to create a
directory structure, one to scp the worker.pl script there, and one to
launch worker.pl). This is done serially in the 0.94 branch. I can see how
this would take very long. I will make some changes to speed up
start-coaster-service, but in the meantime, here are a few suggestions:
1. The SSH slowness seems to only be from the Sullivan head node to the
VMs. SSH connections from one VM to another VM is pretty quick. Are you
able to run Swift and start-coaster-service on a VM?
2. Is a persistent coasters setup needed here? OSDC has an option to launch
instances as a cluster, which makes available a PBS scheduler. You could
set this up and avoid the need to start and manage workers yourself.
Let me know what you think. I have some example OSDC/PBS configs if you
decide to go that route.
David
On Thu, Feb 13, 2014 at 1:04 PM, Matthew Shaxted <Matthew.Shaxted at som.com>wrote:
> Sure thing David,
> I have a setup.sh script that exports WORKER_HOSTS IP addresses from a txt
> file (see attached) - all nodes are running centOS.
> The conf file I am using is also attached. I'm using swift-0.94.1.
> Many thanks,
> Matthew
> MATTHEW SHAXTED
> SKIDMORE, OWINGS & MERRILL LLP
> 224 South Michigan Ave.
> Chicago, IL 60604
> TEL: 312.360.4368
> FAX: 312.360.4545
> matthew.shaxted at som.com
> [image: cid:image9d6458.png at 2965c709.c87949ac]
> WWW.SOM.COM <http://www.som.com/>
> The information contained in this communication may be confidential, is
> intended only for the use of the recipient(s) named above, and may be
> legally privileged. If the reader of this message is not the intended
> recipient, you are hereby notified that any dissemination, distribution, or
> copying of this communication, or any of its contents, is strictly
> prohibited and may be unlawful. If you have received this communication in
> error, please return it to the sender immediately and delete the original
> message and any copy of it from your computer system. If you have any
> questions concerning this message, please contact the sender.
> [image: cid:image93798a.gif at f078f826.ddd94773]
> *From:* David Kelly [mailto:davidkelly at uchicago.edu]
> *Sent:* Thursday, February 13, 2014 12:53 PM
> *To:* Matthew Shaxted
> *Cc:* swift-user at ci.uchicago.edu
> *Subject:* Re: [Swift-user] Coaster Service Startup Time on OSDC
> Hi Matthew,
> Could you please explain a little more about how you're starting the
> coaster-service and workers? Are you using the start-coaster-service
> script? If you are, could you please send the coaster-service.conf file
> you're using? Which version of Swift is this?
> There may be some things we can do to speed up the process - just need to
> get a better understanding of how things are set up and where the delays
> are coming from. Thanks!
> Regards,
> David
> On Thu, Feb 13, 2014 at 12:23 PM, Matthew Shaxted <Matthew.Shaxted at som.com>
> wrote:
> Dear Swift User Group:
> I working with a 60-node cluster running on OSDC now, and when I try to
> start the Swift coaster-service for these nodes, it takes about 30 seconds
> (or more) per node to successfully start.
> This is an issue for me as it limits how often I want to shut down the
> coaster-service - for this 60 node cluster it could take up to 30 min to
> start up again.
> Is this starting coaster behavior normal? Is there anything I can do to
> make the coaster-service start faster?
> Thanks,
> Matthew
> MATTHEW SHAXTED
> Chicago, IL 60604
> TEL: 312.360.4368
> FAX: 312.360.4545
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140217/ef177f1c/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140217/ef177f1c/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140217/ef177f1c/attachment-0001.png>
More information about the Swift-user mailing list
