[Swift-user] Swift stopping because of problematic foreach iteration
Guilherme Gall gmgall at lncc.br
Fri Feb 7 10:34:58 CST 2014
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Em 06-02-2014 16:27, Mihael Hategan escreveu:
> On Thu, 2014-02-06 at 11:09 -0200, Guilherme Gall wrote:
>> How can I address this issue to not leave behind species that
>> would be modeled otherwise?
> Hi,
> If you are trying to have swift run everything it can despite any
> errors in some of the parts of the script, you can set
> "lazy.errors" to "true" in swift.properties.
> Mihael
Hi Mihael,
It is exactly that I'm trying to do. Setting lazy.errors to true did
the trick. Now every iteration that doesn't generate an error is executed.
Thank you for your help.
Guilherme Gall
CSR/LNCC
GPG Public Key ID: A65ED0D5
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.14 (GNU/Linux)
Comment: Using GnuPG with Thunderbird - http://www.enigmail.net/
iQEcBAEBAgAGBQJS9QsyAAoJEG9WBlOmXtDVCz8H/2kwkvm0sZMVZB1L2CfaswhG
ljIW1ocMVKuGf6ztBLqNU408QT1qdegHunWmZlPMt8EqYc+3rjkBqVaAqWTTSwOH
RAc86Y8+JrIMyzEXKPqq1sOTp2Rfdoxc140mzY2R6Y6ZKXHU3E348UmdK2GNOqdS
SIU/KgoTm4DA/ULrRZDkjMlAolMa1dd6DB3tBHfhxF0q0pCJOR8HokmVVmzrXFLR
EKjr4uCrHvAYkb21zOHq78n/Wy9PQ3+qAgMa4tD1FE3upNfaR5ZSAm1c+zUxqbgj
ymiFoOe97Jk2brLz1z/3IGx73NUowv/+puMu4P9U2rKCJu1isnP6udFakVtoTHQ=
=c/Hd
-----END PGP SIGNATURE-----
More information about the Swift-user mailing list
