[Swift-user] empty array in Swift
Mihael Hategan hategan at mcs.anl.gov
Mon Feb 3 12:57:34 CST 2014
Still a bug IMO.
type1 [type2] = []; is a valid statement.
Mihael
On Mon, 2014-02-03 at 18:22 +0000, Wilde, Michael J. wrote:
> The following following should declare an array with no elements:
>   string args[];
> - Mike
> Michael Wilde
> Mathematics and Computer Science          Computation Institute
> Argonne National Laboratory                    The University of Chicago
> ________________________________
> From: swift-user-bounces at ci.uchicago.edu [swift-user-bounces at ci.uchicago.edu] on behalf of Ketan Maheshwari [ketan at mcs.anl.gov]
> Sent: Monday, February 03, 2014 11:44 AM
> To: Swift User
> Subject: [Swift-user] empty array in Swift
> Hi,
> I was working on a problem where user can pass a dynamic number of arguments to an app, including zero.
> A possible Swift script as follows:
> type file;
> app (file _out, file _err) anapp(file _exec, int _i, string _args[]){
>     sh @_exec _i _args stdout=@_out stderr=@_err;
> string args[]=["any", "num", "args"]; # generated via a wrapper script
> file exec<"./echo.sh">;
> foreach i in [0:9:1]{
>     file out <single_file_mapper; file=@strcat("outloc", "/", i, ".out")>;
>     file err <single_file_mapper; file=@strcat("outloc", "/", i, ".err")>;
>     (out,err) = anapp(exec, i, args);
> However, it seems that I cannot have an array with no elements:
> string args[]=[];
> In this case Swift complains:
> Compile error in assignment at line 8: You cannot assign value of type [int] to a variable of type string[int]
> Which works when I say:
> string args[]=[""]
> However, it results in an array with one element.
> So, is there a way in Swift to have an array with zero elements?
> Thanks,
> Ketan
>   string args[];
> - Mike
> Michael Wilde
> Chicago
> ______________________________________________________________________
> To: Swift User
> Hi,
> type file;
> ".out")>;
> ".err")>;
> string args[]=[];
> string args[]=[""]
> Thanks,
> Ketan
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
More information about the Swift-user mailing list
