[Swift-user] __root__ in filename
Mihael Hategan hategan at mcs.anl.gov
Fri Dec 12 18:02:50 CST 2014
On Fri, 2014-12-12 at 16:55 -0600, Ketan Maheshwari wrote:
> After some more experiments it was determined that this does not hold true.
> That is, independent filesys_mappers on a given directory will not pick the
> files in the same order resulting in irregular combinations in the
> resulting tuple.
So it really needs filename to be context aware. I'll let you know when
I have a fix.
Mihael
More information about the Swift-user mailing list
