[Swift-user] env.HOME in sites file not working
    Mihael Hategan
    hategan at mcs.anl.gov
    Thu Dec 11 12:17:28 CST 2014
That said, if you replace {env.HOME} with {user.home}, it should work.
Mihael
On Thu, 2014-12-11 at 10:08 -0800, Mihael Hategan wrote:
> Right. My bad. I don't think {env.XYZ} is something that is supported in
> sites files. Substitution works only for java system properties (e.g.
> {user.home}). Where did you see {env.XYZ}?
> Mihael
> On Thu, 2014-12-11 at 11:59 -0600, Ketan Maheshwari wrote:
> > Mihael,
> > I updated Swift to:
> > Swift 0.95 swift-r8326 cog-r4045
> > It still does not seem to work. The rundir is attached.
> > Thanks,
> > Ketan
> > On Wed, Dec 10, 2014 at 8:49 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> > > Variable substitution was done only in attributes but not in xml text
> > > nodes. This should now be fixed in 0.95 swift r8324.
> > > Mihael
> > > On Wed, 2014-12-10 at 18:52 -0600, Ketan Maheshwari wrote:
> > > > Hi,
> > > > Running 0.95 swift-r8301 cog-r4045, the Swift run crashes when trying to
> > > > set workdirectory to {env.HOME}/swiftwork but works if set with constant
> > > > path.
> > > > The error message is:
> > > > Execution failed:
> > > > Exception in dsp:
> > > >     Arguments: [-f,
> > > > __root__/lcrc/project/NEXTGENOPT/DSP_old/examples/smps/dcap/dcap243_200,
> > > > -a, 1, -n, 1, -p, 1, -I, 10]
> > > >     Host: localblues
> > > >     Directory: dsp.blues-run001/jobs/j/dsp-j4e17i1m
> > > > exception @ swift-int.k, line: 530
> > > > Caused by: null
> > > > Caused by: org.globus.cog.abstraction.impl.common.execution.JobException:
> > > > Job failed with an exit code of 127
> > > > Attached are two identical runs: run001.tgz which failed and run002.tgz
> > > > which worked.
> > > > How can I make it work so that the Swift workdir us not hardcoded?
> > > > Thanks,
> > > > Ketan
> > > > _______________________________________________
> > > > Swift-user mailing list
> > > > Swift-user at ci.uchicago.edu
> > > > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
More information about the Swift-user
