[Swift-user] __root__ in filename
Ketan Maheshwari
ketan at mcs.anl.gov
Wed Dec 10 19:37:15 CST 2014
Thanks! The separate files mapping approach seems to be working.
On Wed, Dec 10, 2014 at 4:16 PM, Michael Wilde <wilde at anl.gov> wrote:
> Here's a few more examples of simpler approaches. These *should* work
> correctly for both relative and absolute filename mappings, even with
> the __root__ convention.
> - Mike
> $ cat regexpmap1.swift
> type file;
> file data[]<filesys_mapper; prefix="f", suffix=".dat">;
> file image[] <structured_regexp_mapper;
> source=data,
> match="^(.*)dat$",
> transform="\\1img">;
> foreach j, i in data {
> tracef(" data[%i] = %s\nimage[%i] = %s\n",
> i, filename(data[i]),
> i, filename(image[i]));
> $ swift ./regexpmap1.swift
> Swift 0.95 RC5 swift-r7605 cog-r3874
> RunID: run077
> Progress: Wed, 10 Dec 2014 22:10:29+0000
> data[0] = f1.dat
> image[0] = f1.img
> data[3] = f4.dat
> image[3] = f4.img
> data[1] = f2.dat
> image[1] = f2.img
> data[2] = f3.dat
> image[2] = f3.img
> Final status:Wed, 10 Dec 2014 22:10:29+0000
> The simplest approach is to just map one array to each file suffix. The
> filesys mapper will return the files in the same lexicographic order for
> each pattern:
> $ cat ./regexpmap3.swift
> type file;
> file data[] <filesys_mapper; prefix="f", suffix=".dat">;
> file image[] <filesys_mapper; prefix="f", suffix=".img">;
> $ swift ./regexpmap3.swift
> RunID: run078
> Progress: Wed, 10 Dec 2014 22:10:56+0000
> data[2] = f3.dat
> image[2] = f3.img
> data[3] = f4.dat
> image[3] = f4.img
> data[0] = f1.dat
> image[0] = f1.img
> data[1] = f2.dat
> image[1] = f2.img
> Final status:Wed, 10 Dec 2014 22:10:56+0000
> swift$
> On 12/10/14 3:52 PM, Michael Wilde wrote:
> > This example may be helpful:
> > $ cat -n regexpmap.swift
> > 1 type file;
> > 2
> > 3 string fnames[] = [
> > 4 "/data/dir/000001/f01.dat",
> > 5 "/data/dir/000001/f02.dat",
> > 6 "/data/dir/000002/f03.dat",
> > 7 "/data/dir/000002/f04.dat",
> > 8 "/data/dir/000003/f05.dat",
> > 9 "/data/dir/000003/f06.dat"];
> > 10
> > 11 file data[]<array_mapper; files=fnames>;
> > 12
> > 13 file image[] <structured_regexp_mapper;
> > 14 source=data,
> > 15 match="(/data/dir/[0-9][0-9]*/.*?)dat$",
> > 16 transform="\\1img">;
> > 17
> > 18 iterate i {
> > 19 tracef(" data[%i] = %s\nimage[%i] = %s\n",
> > 20 i, filename(data[i]),
> > 21 i, filename(image[i]));
> > 22 } until (i==6);
> > $ swift regexpmap.swift
> > RunID: run067
> > Progress: Wed, 10 Dec 2014 21:50:42+0000
> > data[0] = __root__/data/dir/000001/f01.dat
> > image[0] = __root__/data/dir/000001/f01.img
> > data[1] = __root__/data/dir/000001/f02.dat
> > image[1] = __root__/data/dir/000001/f02.img
> > data[2] = __root__/data/dir/000002/f03.dat
> > image[2] = __root__/data/dir/000002/f03.img
> > data[3] = __root__/data/dir/000002/f04.dat
> > image[3] = __root__/data/dir/000002/f04.img
> > data[4] = __root__/data/dir/000003/f05.dat
> > image[4] = __root__/data/dir/000003/f05.img
> > data[5] = __root__/data/dir/000003/f06.dat
> > image[5] = __root__/data/dir/000003/f06.img
> > Final status:Wed, 10 Dec 2014 21:50:42+0000
> > On 12/10/14 3:21 PM, Mihael Hategan wrote:
> >> Hi,
> >> In 0.95 this is a bit of a known problem. This should be fixed in trunk.
> >> A backport of the fix may be possible and should probably be done. Can
> >> you easily switch to trunk? If not, I'll try to do the backport sooner.
> >> Mihael
> >> On Wed, 2014-12-10 at 15:11 -0600, Ketan Maheshwari wrote:
> >>> Hi,
> >>> In an app that needs input files with same name but different
> extension, I
> >>> am trying to use regexp on the filename() of a mapped file. However,
> Swift
> >>> adds '__root__' to the path of file which cause the file to be not
> found in
> >>> the new location resulting in error as:
> >>> org.griphyn.vdl.mapping.MissingDataException: File not found for
> >>> variable 'in_sto':
> file://localhost/__root__/lcrc/project/NEXTGENOPT/DSP_old/examples/smps/dcap/dcap332_500.sto
> >>> Relevant code is:
> >>> file timfiles[]<filesys_mapper;
> >>> location="/lcrc/project/NEXTGENOPT/DSP_old/examples/smps/dcap",
> >>> pattern="*.tim">;
> >>> file in_sto <single_file_mapper; file=regexp(filename(timfiles[0]),
> "tim",
> >>> "sto")>;
> >>> Thanks for any workaround suggestions for this,
> >>> Ketan
> >>> _______________________________________________
> >>> Swift-user mailing list
> >>> Swift-user at ci.uchicago.edu
> >>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
> Michael Wilde
> Mathematics and Computer Science Computation Institute
> Argonne National Laboratory The University of Chicago
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20141210/cea23401/attachment.html>
More information about the Swift-user
