[Swift-user] __root__ in filename
    Michael Wilde
    wilde at anl.gov
    Wed Dec 10 15:52:00 CST 2014
This example may be helpful:
$ cat -n regexpmap.swift
      1    type file;
      2
      3    string fnames[] = [
      4    "/data/dir/000001/f01.dat",
      5    "/data/dir/000001/f02.dat",
      6    "/data/dir/000002/f03.dat",
      7    "/data/dir/000002/f04.dat",
      8    "/data/dir/000003/f05.dat",
      9    "/data/dir/000003/f06.dat"];
     10
     11    file data[]<array_mapper; files=fnames>;
     12
     13    file image[] <structured_regexp_mapper;
     14      source=data,
     15      match="(/data/dir/[0-9][0-9]*/.*?)dat$",
     16      transform="\\1img">;
     17
     18    iterate i {
     19      tracef(" data[%i] = %s\nimage[%i] = %s\n",
     20             i, filename(data[i]),
     21             i, filename(image[i]));
     22    } until (i==6);
$ swift regexpmap.swift
Swift 0.95 RC5 swift-r7605 cog-r3874
RunID: run067
Progress: Wed, 10 Dec 2014 21:50:42+0000
  data[0] = __root__/data/dir/000001/f01.dat
image[0] = __root__/data/dir/000001/f01.img
  data[1] = __root__/data/dir/000001/f02.dat
image[1] = __root__/data/dir/000001/f02.img
  data[2] = __root__/data/dir/000002/f03.dat
image[2] = __root__/data/dir/000002/f03.img
  data[3] = __root__/data/dir/000002/f04.dat
image[3] = __root__/data/dir/000002/f04.img
  data[4] = __root__/data/dir/000003/f05.dat
image[4] = __root__/data/dir/000003/f05.img
  data[5] = __root__/data/dir/000003/f06.dat
image[5] = __root__/data/dir/000003/f06.img
Final status:Wed, 10 Dec 2014 21:50:42+0000
On 12/10/14 3:21 PM, Mihael Hategan wrote:
> Hi,
> In 0.95 this is a bit of a known problem. This should be fixed in trunk.
> A backport of the fix may be possible and should probably be done. Can
> you easily switch to trunk? If not, I'll try to do the backport sooner.
> Mihael
> On Wed, 2014-12-10 at 15:11 -0600, Ketan Maheshwari wrote:
>> Hi,
>> In an app that needs input files with same name but different extension, I
>> am trying to use regexp on the filename() of a mapped file. However, Swift
>> adds '__root__' to the path of file which cause the file to be not found in
>> the new location resulting in error as:
>> org.griphyn.vdl.mapping.MissingDataException: File not found for
>> variable 'in_sto':
>> file://localhost/__root__/lcrc/project/NEXTGENOPT/DSP_old/examples/smps/dcap/dcap332_500.sto
>> Relevant code is:
>> file timfiles[]<filesys_mapper;
>> location="/lcrc/project/NEXTGENOPT/DSP_old/examples/smps/dcap",
>> pattern="*.tim">;
>> file in_sto <single_file_mapper; file=regexp(filename(timfiles[0]), "tim",
>> "sto")>;
>> Thanks for any workaround suggestions for this,
>> Ketan
>> Swift-user mailing list
>> Swift-user at ci.uchicago.edu
>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
Michael Wilde
Mathematics and Computer Science          Computation Institute
Argonne National Laboratory               The University of Chicago
More information about the Swift-user
