[Swift-user] Debugging Swift Coaster ServiceManager
TJ Lane
tjlane at stanford.edu
Sat Jun 15 23:23:06 CDT 2013
Awesome thanks guys -- makes sense. I'll see if I can get our sysadmin to
install it and get back to you if it doesn't work.
On Sat, Jun 15, 2013 at 8:06 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> On Sat, 2013-06-15 at 19:11 -0500, Michael Wilde wrote:
> > The more I look at the error the more it looks like the coaster service
> on biox3 is getting a null pointer exception "at
> java.net.URI.compareTo(libgcj.so.10)" and that may be the root cause.
> > We dont to my knowledge test on open source Java's yet, although we have
> discussed this.
> > We used to see lots of incompatibilities with Swift on them, but these
> have been diminishing.
> > Can you test again after making sure that Java 1.6 or higher is in your
> PATH on biox3?
> Right. We don't support the GNU java thing. Things should, however, work
> on OpenJDK or IcedTea.
> Mihael
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20130615/056f08a6/attachment.html>
More information about the Swift-user
